Hi guys
I’m still struggling with getting that first perfect smooth bottom layer - this is important for aesthetic purposes.
Basically - layer lines are visible on the bottom layer surface in random places.
In this case textured sheet is not the answer. (even with certain textured sheets - sometimes the lines still occur)
When I paint these surfaces the gaps are more pronounced - see pic.
I’ve tried adjusting flow settings, heat settings on both bed and nozzle - different filaments etc - speeds, line widths -
In short all I want to do is squish my z a bit more and I think my problem will be solved. I’m sure the automatic z calibration is just a tad off.
Bambu Labs refuses to make this an adjustment that can be set in the settings or on the hardware menu , so I assume I need to adjust the starting gcode.
If this is the case and I am using an engineering plate (I like the subtle texture it leaves)
what settings would I need to add , at what increments and where do i add them exactly?
I don’t want to mess anything up on my other models - just need the setting for this model.
Appreciate your help - I’ve been troubleshooting this for some time and I’m at my wits ends.
As you see in the pic - I want the entire bottom layer uniformed.
Thanks.
