TLDR: Get a MERV 14 filter (should also be rated HEPA). Avoid knockoff filters. Get a filter with carbon as well to handle VOCs. Vent your X1C right next to it. Use PLA. Keep the door open and crack the window while printing for additional air circulation, which will reduce breathable particle concentration. Wear a K95 when pulling the print out or sniffing the exhaust port. Avoid ABS white. Buy a PM 2.5 meter like the temtop m10. Probably don’t sleep next to it printing.
Once you’ve done all this, you can take some of the other steps recommended by the community such as setting up a venting system to the outside, or dedicating an unoccupied room to printing. Neither are particularly viable for me because it’s extremely cold right now and I have zero unoccupied space. Once I did the steps above, I felt comfortable having the kids in my office to watch the printing process through the window.
It’s important to remember that the small particulate size generated by this type of 3D printer cannot effectively be captured by a HEPA filter
This is a lie propagated by filter manufacturers. They want to sell higher grade filters, so they say “small things can get through big holes, so buy our best filters, or this $1000 specialized ultra fine filter.” The truth is that small particles clump, catch onto things, or do other weird ■■■■ because of brownium motion and other science ■■■■. HEPA filters are actually more effective at catching smaller particles.
Here is the typical efficiency curve of a 99.99% hepa filter.
In fact even the shittiest HEPA filters can catch small particles.
This is the efficiency curve that the filter manufacturers will show you to mislead you.
N95/KN95 masks also have a similar efficiency curve. Even shitty masks will offer some protection.
Can’t find the graph, but some cheap filters marketed as HEPA have bad efficiency curves that actually go down. So avoid knockoffs and only purchase from reputable sellers.
There’s a small dip in efficiency from .1 to .3 microns, which is where the most dangerous 3D printed particles are, but running a good HEPA filter with high rates of airflow will absolutely clean a room and make it healthier. If you add a carbon filter to handle VOCs you can probably eliminate most of the risks associated with PLA.
Also, I advise everyone to read this NIH study Monitoring of Particulate Matter Emissions from 3D Printing Activity in the Home Setting - PMC
Here’s a tldr if you don’t feel like it:
- Lower extruder temps = less particle concentration
- faster exhaust speeds on x1 = less particle concentration
- good brand = less particle concentration (though no brands disclose their chemicals).
- good color = less particles (avoid abs white).
- lower infill % = less particles
- highest danger is when the extruder first starts heating up, then it lowers over time until reaching a baseline while printing. Basically stuff settles over time.
- a pm 2.5 monitor, while it can’t detect particles in the 0.1-0.3 micron range effectively, will provide a relative estimate of particle concentration over time that is still useful. For example, it will hit the maximum reading later than a $1500 meter, but also retains higher readings over time, which can lead to more conservative actions by the operator, thus increasing safety. One possible pm 2.5 meter recommended by nytimes is the temtop m10.
One of those PLA manufacturers is basically putting tons of harmful ■■■■ in their filament, but the study kept the brands anonymous. Only way to change this is for customers to push manufacturers into revealing additives and make disclosing of additives mandatory.
