(By infill I assume you mean the sparse infill density unless I’m missing an option.) Taking a look inside the model it looks hollow? I assume the bridging will still print, though. I also would like for there to be infill between the walls of the model, just not in the cavity outside the walls. (I wish I could post the stl and blender file to explain but it seems I can’t.)
Since the bottom closes right where the globe & the base are joined, I would look at that in Blender. My guess would be that you have a floor on the globe before you added the base.
Thank you, but I’m very sure that I didn’t accidentally create a floor where the semi-sphere and ring connect. I took another look in edit and object mode and I don’t see anything anomalous. Do you see anything that I could be missing?
You should be able to upload a .3mf project file. This is usually more useful than a stl file since it will let us see the model AND all the settings you are using.
Hey Cats, just a heads-up. Many here don’t like GRID (ty @moonrakerone!) infill because where the extruded strands cross there ends up being a peak that the extruder keeps hitting. All those crossings and peaks cause stresses as the extruder nozzle whacks them and it’s “like thousands of tiny fingers urging your model to let go.”
And let go they can - especially with tall models or models that don’t have much build plate contact area. Many suggest gyroid instead.
Oh! Thank you for the heads up about rectilinear infill, I didn’t know that. I’ll see if I like gyroid for my next project. Anyway, here are the links to my work:
Download STL. Don’t have a printer big enough for BS or Orca, I did load it though & it threw some mm inch errors.
I loaded in to Cura & threw some error also.
OK, I reduced the vertex count and ran it through Slic3r again, it looks like Slic3r thinks the bottom is unfortunately solid. Now we know it’s not just a problem with Bamu Studio.
Oof, Cura isn’t working either. Now I really have no idea how to fix this. I’m thinking of giving up and making the base/cylinder twice as tall and just hoping it prints with supports or something.
