Multi-color text to the surface of an object in Bambu Studio
Hi everyone,
I’m using Bambu Studio 2.8.2.61 with a Bambu Lab P2S, and I’d like to add text to the surface of an object, such as a box or its lid.
The text should have a different filament color from the main object, but it should be completely flush with the surface — neither engraved nor raised.
I know how to add text using the Text tool, and I have already managed to create engraved text. However, I can’t figure out how to create text that is integrated into the surface at the same level, using a different filament color.
What exactly do I need to do in Bambu Studio to achieve this?
  • Which text settings should I use?
  • Does the text need to be part of an Assembly?
  • How should I position the text and set its thickness or depth?
  • How do I assign a different filament color to the text while keeping it flush with the object’s surface?
I’d appreciate a step-by-step explanation of the correct workflow.
Thanks in advance for your help!
Modifiers are amazing
Use the text tool to create what you want it to say, change type to a modifier, place it where you want it, then change filament on that modifier.
Just add the text and paint it
