I’ll play. I have had nothing but trouble with the P2S! Blobbing, skipped layers, freeze-ups, etc. Now I don’t actually own the printer and haven’t actually used one, but I’m pretty sure it would have behaved just like that if I had.
P1S works beautifully with Glacier plate no glue. I’ve used my first P1S for a couple of years before I got the P2S and the second P1S 6 months later. Cryogrip Glacier, 95c bed, 265c nozzle, 10mm brim and it’s perfect every time.
I have a deflector and tried higher temps like 110c bed on the P2S, Even made sure it was the same Cryogrip plate incase one worked better than the other. I also did high temp calibration on the P2S.
There were under extrusion problems around 100c and a lot of people were having these problems. I should probably try it again, there has been a couple of firmware updates since I last tried it. I did a ton of tests and wasted a couple of KG of polymaker ASA before giving up and getting a second P1S. The pic above is from soon after I got the printer. Early in the year. I don’t have anything newer, but the times I tried small 2 inch square pootprint pieces maybe 6 months ago, the corners still lifted like that. P1S does everything like a champ.
P2S does fine with basic PLA and PETG filaments. That and printing prototypes in PLA because it prints faster and is cheaper than ASA.
It’s really interesting to read your review, because I’ve had roughly 70 hours of printing on my P2S so far (coming from an Ender 3V2 Neo) and I am constantly impressed at what it’s done.
I’m particularly impressed with the handy app as printing before could sometimes be a hassle, or at least more time consuming than just scrolling on the handy app, picking a model, selecting my filament, and hitting print.
No wasting time with a piece of paper to level the bed, beyond easy color/material changes, and it’s drying my old filaments that have been sitting in a storage box for 1-2 years.
I’ve had multiple color prints come out well, and while I’ve only used PETG and PLA so far, I could not be happier with this printer. Granted I think my opinion is swayed because it feels like I went from stone age with the Ender 3V2 to space age with the P2S, and I don’t want my review to sound like a sponsored ad, I’m just wondering if there is something wrong with your specific printer.
I assume you’ve run through the calibration/setup more than once if you continue to have the same problems, maybe go to a microcenter and see if they can find something wrong with it?
My one-month old P2S is printing polymaker PETG when I am typing this reply. Room temperature is 30 deg C , Aux fan in cooling mode running at 40%, bed temperature is 70 , chamber temperature is 43 and very steady. door closed and top glass in place. May be I got lucky or something.
My sons put there savings together to buy one of these things. What I didn’t know was I should have went to school first and got a electrical engineering degree. Out of the box, prints were flawless. for about two weeks. Week three, spahgetti, scraping, etc etc. I am dealing with support now and I was getting a ticket response within 24 hours. Now its two days. Maybe you can help me with my issue. I have performed all of the following,
P2S first-layer adhesion/Z-height problem after approximately two weeks of excellent printing.
Printer initially printed perfectly, including multiple successful copies of the exact same model. It then suddenly developed severe first-layer problems.
Troubleshooting already performed:
- Thoroughly cleaned factory textured PEI plate
- Checked underneath build plate for debris
- Full printer calibration performed
- Bed leveling enabled
- Bed temperature tested at 60°C
- Nozzle cleaned and inspected
- Manual extrusion is smooth and consistent
- Hotend/nozzle checked for looseness and appears secure
- Bed checked for abnormal movement
- Tested two different PLA spools with the same results
- Printed single-layer test squares in different bed locations
- First-layer calibration adjustments of -1, -3, -4 and -5 tested
- More negative first-layer adjustment improves the result but does not eliminate the problem
First layer is inconsistent. Some lines/perimeters adhere correctly while nearby small features curl upward, detach and are caught/dragged by the nozzle. Test squares also show inconsistent line fusion across the first layer. Service told me to do this, there is a communication anomaly between the MC board and the AP board. We recommend referring to the guide below to reseat (unplug and firmly replug) both ends of the MC-AP cable, and then print the first-layer test model again to see if the issue improves:
So, that is what I did. Halfway through the process I am thinking for $800 I should not be doing this 3 weeks after purchase. Here is the test print they had me perform after disassembling this thing and reassembling and print I performed after that. Maybe you have some advice or can point me in the right direction because support is not helping at all.
Looks like I cant put photos in the post.
Now the only thing I could ask would be how did you cleaned the PEI plate? Any chance that you have used some detergent with skin oiling and softening agents? And now there is no way something to stick to it? Usually for washing my glasses and for the plate I am looking for crystal clear looking washing detergent/liquid soap as usual matte color means this is emulsion with some oils. Then of course you need to read what else is inside as there are crystal clear softening options too. But usual the cheapest liquid soaps ( have in mind that strong perfume could also leave some residue) and washing detergents has no or very limited amount of such agents, as they are cheap
All else seems to be checked from your side, but this small detail is missing.
Hope you will find the fix and boys will go out from sad to creative mode ASAP! ![]()
BTW electrical engineering will have no help here, you will need also some chemistry and physics
Forum says your first post so just a suggestion but create a new topic rather than piggybacking off an old topic. Youll get better response.
Bambu filament?
I replaced mine and since than … knock on wood … most things are running fine
