My review of the X2D after 200+ hours
It’s all fine and dandy, until you realize that the secondary extruder suffers from constant under-extrusion. So it prints supports that are more brittle (due to being weak from under-extrusion, and bad layer adhesion) and break easily.
I had many many prints break mid-way, because the bowden-printed supports simply broke mid print due to bad (under-extruded) layers somewhere mid-support, which made it structurally weak once the main extruder (with higher speeds) tried to print something on top of them.
I can’t say in my now near 600 hours and various complexities of prints that I’ve had this issue, past the personal skill issues that I had with the aux extruder gear clog (documented in my post) the machine has been confidently going BRRR and spitting out parts.
Have you tried talking to support about it? I’d be curious to get nerd-sniped by this and help you troubleshoot it if you’re down…
I’ve also read your post about it and it really sucks that you’re experiencing the issues you are. I’m not by any means trying to say that you’re not having problems with it, but it seems that it’s either a process/expectation mismatch or you’ve unfortunately got a lemon of a machine, which does seem to be something that’s started happening more and more with Bambu.
The additional “gear”, I’m with you on, the track switch, etc are all, in my opinion, garbage and rushed products to try bandaid drawbacks, or address potential customer expectations that the machine isn’t necessarily designed for from the ground up.
Overall, 400 hours since I initially wrote my review/opinion piece and after having conversations in this thread and seeing more potential issues that other users had, I think I will stick with my original conclusion, which was TL;DR:
Do NOT get this machine if you’re a beginner or expect the typical clean bambu experience out of the box. Be it hardware integration, firmware or Bambu studio, this is not the typical “appliance” machine.
The OP touts the X2D as excellent printer for dissimilar material support, but I’ve found that it makes great two-color prints, and with two A2Ps and appropriate positioning of spools, its not bad for smaller tri-color and quad-color prints. I’ve found the print quality of the aux extruder to be 100% fine.
Its interesting to compare the ease of multicolor printing with the X2D compared to the new multi toolhead machines. For sure the multi toolhead machines are faster and will have less waste, but one thing that I’ve come to greatly appreciate with my X2D is the awesomeness of the A2P. It is so freaking convenient for swapping spools and drying filament. And with two A2Ps, there is a pretty good chance that the color I want is already installed, but if it isn’t, it only takes 30 seconds to install it. And I don’t have my filaments sitting out in the air picking up moisture (which is important to me because I’m all-in on PETG).
Interestingly, it was suggested to me as a great first printer. I was just about to pull the trigger, but I’ll do more research.
All plastic printers are somewhat complicated if they are being used as more than a replicator for Makerworld items. The second print head on the X2D, which offers many benefits, does make the printer more technically challenging to use, but not by much.
Whether the X2D is a good choice for a given person is another story. The Snapmaker U1 is pretty compelling if your primary interest is creating multicolor prints that would most likely be made from PLA. And there are several other multihead printers coming to the market right now.
Definitely do.
While the secondary nozzle offers some benefits, it does make the printer setup & maintenance more complex, and the added complexity also makes it more failure prone.
I honestly don’t think it’s a “great first printer”. I personally would have recommended a P2S or even A1/A2 for someone just starting out and getting a first printer. They are both cheaper, and simpler.
I have a good progress with my first layer issues so far:
And I can agree that X2D could be good PLA printer ( IF YOU DO NOT USE IRONING). As even with all the inconsistency with under extrusion it can print PLA 24/7 with both extruders. BUT if you try to use the second extruder for something else like - support, PETG, different nozzle and etc, now you have real challenges. But this printer is neither marketed as PLA printer nor the price is right. :smiley: And if you try to use the second extruder expect to get much longer print times.
It absolutely could be 1 button makerworld replicator if you just use PLA on both nozzles, and use only 0.4 nozzles. All else will make you learn :smiley: , to say it in positive way. And sometimes you may need to change G code or wait for fixes and updates.
I have an X2D and have been printing objects while using support material interface with supports. It has been printing exactly as it has been promoted to work. It prints in a fraction of the time it takes to print the same things on an X1-Carbon, thanks to the auxiliary nozzle.
Over years of 3D printing, it seems to me that I have never had a problem with under extrusion. Makes me wonder what people are doing to cause it.
Yeah, next thing would be to suggest I am AI bot and I do not even have a printer right? :smiley:
Fraction of the time can be possible with the AUX if you maybe print 240x240x240 big object in dual colors. And change color every 5mm. Then instead 1 year you are doing it now for only 3 months? :smiley:
Jokes aside, I am happy it works great for you! But this does not help me, or some of the many others which do have badly working printers.
BTW support works for me, sometimes also. So far it was NEVER faster compared to using the same material. And when I say never I mean never. If you can show me some model that will be faster with support on AUX compared to the same material I will be happy to check it out. Even only the usage of prime tower adds to the print time a lot. Now if you talk that you compare main extruder with one material + support material again on main, and then main extruder + AUX for support it may have some benefit depending on the object and materials.
I don’t think anyone thinks you are a bot, but your experience differs from some or possibly many people. With the exception of using PLA for support interface, I only print PETG, and I do it from either nozzle without issue. The print quality from the aux nozzle is as good as the primary. It doesn’t matter if I use Bambu, SUNLU, or Creality PETG (although I only have one role of Creality). Solid or translucent.
I do print hot (255C) and relatively slow, and I dry the crap out of my filament. New filament gets dried before first use. Generally my AMSes sit below 10% RH. If RH drifts above 15%, I will bake for 8-12 hrs at 65C. All my unused filament goes in dry-boxes with desiccant.
Thank you for your feedback though! It is nice when actually community have people like you, and many others which actually genuinely try to help and try to communicate! Thank you! Maybe you do not believe me on the first read but at least you try help, troubleshoot and share! I am actually learning a lot from people like you!
The external drier is the first thing I bought after the printer. As I found I can not dry while printing with AMS 2 PRO. Or I need to add power supply ( expensive and not available local ) to be able to do so. Then the chamber inside is shared and you can soften the material which is used for print. Then you need higher temp for some materials, but if they are loaded you can not rise the temp above 45C, and so on and so on stuff, that you see later. So I figured out external/separate drier is a must! So I never had wet filament inside the machine. I do not have good boxes for now, but reuse the nylon bags from the Polylite filament which I got in the beginning, with desiccant bag inside. So I have the PLA and few PETG rolls either dry in the drier/AMS, or in the nylon bag with desiccant. And Bambu itself does not really care of how dry is PLA as they sale A1 series with open AMS…
But if you look around you will see die hards or just trolls which said this ( troll, AI bot, even do not have the printer and just bad mouthing the “holy company” ) not only to me but also to other people! Without any proof or something, someone is talking against their team so they need to fight you down, kick you out, and show you the door. Shame on you guys! This is not some football, hockey or basket game, I am spending the money from my pocket and expect to get the promised quality from the ads. Which is not the case for ME. And there are clearly design flows which can be seen from the outer space.
Then the second wave of frustration - you have no clue what you are doing, go read the docs and wiki, learn how to calibrate, dry the filament and wash the plate :smiley: . And this is general advise even when the issue has nothing to do with the wet filament and adhesion :smiley: . Like - my extruder temp sensor got defective - ohhh you are not properly maintaining your printer!!! Exactly what maintenance you do on you extruder nozzle temp sensors??? Then 20 notes how stupid he is and how realistic are his expectations, he knows nothing and etc blah blah… sad story!
I have got UNDER extrusion. Which I got from day one, out of the box, absolutely free! What about I am calibrating in the last 3 months and nothing got better? Ohhh you are clueless troll :smiley: :smiley: :smiley:
Now If I had the knowledge and experience from the start so I could recognize that printer is misbehaving, and I am not actually clueless troll, I would have returned the printer. But I am listening to the whole internet crowd how flawless are Bambu ( psychology - pressure from the crowd ) and how the problem should be ME. Like ok this guys has experience maybe they are right. But actually they are NOT, and actually very few of them has the printer and use it every day. So this toxic behavior need to stop, or it will destroy the community.
But actually the forum helped me a lot to rethink the whole story. Especially as I saw maaaany people swapped their A1/P1/X1 and “upgraded” to X2 not able to replicate even the simplest quality tests. Then I started to figure out something with this device is really wrong, and I had missed the return window because of the vocal clue-less people, blindly believing in the Bambu rightness. So now you can see me to be vocal against this nonsense, and showing the real qualities of the X2D printer. Which it seems are very similar to the H2D/C series :smiley: . As they seems to share a lot of the platform HW and SW.
My experience has not been that great, with in the first month I had nothing but String issues and cohesion issues. Then print head did something and shorted out the system board. It took 3 weeks of jumping through hoops to get a new printer, mainly because they were very resistant to replace it, they want me to fix it with free parts. When I researched this the overwhelming response was not to do it, because if you mess it up, or it is a different issue, Bambu will blame you and then you are on your own to repair.
When I finally got the new printer, it worked great for 4 weeks, and now the pneumatic connector located above the Left Filament Sensor is damaged. and the Left Filament Sensor would need to be replaced. Getting this part under warranty has been another game of jumping through hoops. I have no idea how it broke, I never touched it, all I can think of is the part is not sturdy enough for all the back and forth the head does.
On a positive note, when the 2nd printer was working, it worked great! No string issues, no misalignment, everything is nice and smooth.
What part of the world you live in? I am kind of surprised how some people say bambu support is greatest and other say very slow and pain. Wondering if this is geography replated or just whoever is on shift?
I think it often has to do with how people treat service representatives. People that are calm and accommodating seem to have great experiences while people that storm in with a chip on their solder making demands often seem to have a different experience. I’ve worked in technical service and some people are great while others are extremely mean and rude.
If this is true this would mean the support is based on reaction and not on some kind of standards. And also we have zero proof this is the case here. This is why the soft skills exist basically.
Honestly I do not think this is the case.
I think this is mostly true. My support tickets are usually solved within a week. As in I open the ticket including the troubleshooting I have done, then they send me out the parts that I requested.
It is a straight forward process if you allow it to be.
Problem is that so many people that are buying these machines nowadays do not want to work on them.
Although there are definitely times where you get stuck in a support loop.
Lets say this … “Willingness to cooperate with support”.
Great post. The machine has worked great for me so far except when it comes to ironing and top surfaces. They’re awful. I’ve done calibrations and the ironing tools found on maker world. I’m new to 3D printing and trying to troubleshoot this for a consistent and clean surface print has been a huge time suck and a total drag…
