wanted to check the screws on the mounting plate but couldt get my nozzle out.
I tried to pull out the nozzle, but I noticed some resistance. After a closer inspection, it seemed to be a leftover piece of filament.
I had to heat up the nozzle first, purge a bit of filament, and then, while it was still warm, I was able to unload the filament and remove the nozzle.
From the pictures, you can see what kind of piece was still stuck inside.
By the way, it’s just regular PLA.
Now the question is – what was the cause? Did the cutter not work properly, or was it something else?
Some people get their hot-end clogged because they load PLA in the hot-end when it shortly before was used for printing filament with high temp. The higher temperature in the cooling zone melts the PLA and makes it stick to the wall and does not release anymore at PLA temperatures.
I’ll fully admit I’ve just been doing it without much knowledge… what is the correct process for a nozzle change? I’ve just been cutting them with the cutter, removing the nozzle and then yanking the little remainder out with pliers. Is there a retract action or something do first?
Think u didnt read ?
The nozzle couldnt be changed, because the filament was still so stury, that the nozzle didnt became loose…
I needed to heat the nozzle, to get the pla soft again
Next time just hit the cutter a couple times. The only time I had problems was before I realized I had to take the front clear cover off first, or the nozzle slightly snags on it. Also pull toward you and then down.
I’ve had similar challenges with the nozzle change. It seems the right nozzle consistently has the longer piece but both leave filament in the nozzle. I did a few different experiments when I couldn’t find definitive instructions on how to deal with a used nozzle change. I heated the nozzle with a lighter after removal and it cam out easily. The left nozzles was too short so I just re-installed and purged and that worked too. So as mentioned above, I don’t think it much matters.
I’ve been researching this same issue of a segment of filament still seeded at the top end of the removed nozzle; if someone has a link to a solution or explanation of why I should not be concerned, would really appreciate it.
