Nozzle Dragging on Print - this can't be normal
Thank you all - while I have you - I am trying to dial in the right settings to get a glossy sheen on my outer walls and I am almost there - however I can’t figure out what the reason for the different sheen is near the through holes - I slowed down the prints enough and raised the temp and lowered cooling to get it almost perfect but yet the through hole areas are of a different sheen and the software color map is not showing it - can you see this post and perhaps make a recommendation? Thanks
