Hello,
I recently started getting this HMS code (0300_0100_0003_0008) on my P1P and I’m not sure what it represents as it doesn’t seem to be documented on the HMS code list. The code appears as soon as a print is started and is present throughout the entire print. I do not have an AMS system nor do I have a chamber fan installed. The error doesn’t seem to be affecting the prints, but it is bugging me.
I found what it was it is when you try to set the bed temp higher than the limit its just telling you that it is automatically lowering it and that you should check your filament settings
Anyone know how to adjust the max? 100C is not quite enough for ASA, really. Having to use glue and wash the plates all the time is not ideal. Seems doubtful the hardware couldn’t actually handle it!
That stuff is good, and easy to clean up when used on smooth PEI or holographic transfer sheets. Also you don’t loose the hologram vs. using products like Magigoo.
Nevertheless this limit, along with the 300ºC hotend limit just seem like not–so -subtle nudges to buy the more expensive products. It would be so much more useful with support for 320ºC nozzle, 80ºC chamber and 135ºC bed and it seems like this hardware could do that easy. It could probably get that hot in the chamber using insulation if it was just allowed in the software. Well, I’m not that bad about it, it just means I’m spending my printer money on Voron and/or Ratrig parts, not Bambu Lab. Their loss.
