P1P & P1S parts
I printed the vision enclosure and ordered Plexiglas. Later, I realized I should replace the MC board fan, so I also ordered the P1S Heatsink for the MC Board, Chamber Temperature Regulator Fan, Control Board Fan, Cable Chain Assembly, and the rear panel.
Once everything is installed, should I follow the instructions on the wiki and select the upgrade route on the LCD, or just add the MC code?
And for the chamber fan, there is no code needed?
Thanks for helping out
up, parts comming this week
Try the option on the LCD
Was thinking the same, will try it today.
parts are all here, but i didnt order the auxiliary cooling fan.
So lets hope the upgrade mode will not brick ^^
So installed everything today, MC board fan, P1S Heat sink, Chamber Temperature Regulator Fan, Control Board Fan, Cable Chain Assembly, and the rear panel.
Selected upgraded in LCD, did a calibration, now i don’t know why or what i didn’t buy.
but I DON’T see my chamber temp…
How can I fix that, or what I’m missing in the kit?
The P series doesn’t have a chamber temperature sensor, only the X series.
The best work around I’ve found is to put a temperature display inside the chamber that is viewable via the camera.
Okay! rofl, my bad! thx man for the headsup, will look for one.
Thx again!
