P1P/P1S upgrade--Transferring filament user presets?
I finished my upgrade and also updated firmware to 1.05. When changing my printer on the prepare page from the P1P to P1S I lose all of my User presets for filaments. I could see that this could be a problem going from 2 different machines as the calibrations would likely be different but in my case it is the same machine and I would really not want to do the 11 presets all over again. I found the presets folder and tried copying one and changing the “P1P” to “P1S” in the title and the Json file. It still does not show up in Orca.
Is there a way to transfer these filament profiles easily?
If I switch the machine back to the P1P they all show up again.
Scott
Open the copied profiles with a text editor. Within the json files are references to P1P. Change these to P1S and import them via File menu → Import…
@ print.in.3d Thank you very much for your reply
I had opened the json files and changed any reference of P1P to P1S. I did not try to “import” them. I have tried that and still no joy.
I have changed the file name and all reference inside to P1S and then imported. see screenshot below for result returned.
and this is the text in the json file
Scott
For the record I tried the import in both BS and Orca, same result. ( my screenshot shows Orca )
Scott
Any luck? I’ve been trying to do this for hours. When I import a JSON, it goes to my P1S, but I need it in my P1P
Hi, typing this out from scratch because I keep seeing this pop up and people always miss out the step that makes it able to sync to the printer/cloud/AMS… so:
Close Bambu Studio and force quit Handy App if you use it
Go to
“C:\Users<your user name>\AppData\Roaming\BambuStudio\user<long number>\filament\base” or type %appdata% and browse the rest
Open the .json filament you want to copy to any machine, example, copying an X1 profile to a P1S
Open in notepad and save as in the same folder with the same naming convention but for the p1s (or whatever you’re moving it to)
Soooo essentially the same name as the name of the printer you use in Studio after the @:
3D Jake PLA White @Bambu Lab X1 Carbon 0.4 nozzle.json
Becomes
3D Jake PLA White @Bambu Lab P1S 0.4 nozzle.json
Or
3D Jake PLA White @Bambu Lab P1P 0.4 nozzle.json
or
3D Jake PLA White @Bambu Lab A1 mini 0.4 nozzle.json
Now select all in the file and go to Find and Replace - Multiple Text Online - Tools - Joydeep Deb
Paste it into the top box
Scroll down to line 15 and copy the text between the quotes
scroll down to the first find and replace and paste that text into find 1 and in replace you’re using the same as you put in the file name: Bambu Lab P1S 0.4 nozzle
scroll down and click find and replace
Right click in output data and select all
copy that straight back into your notepad file and save again
One last change, find this section
and replace ANY letter or number from the filament id section keeping the same length and format, so I’m replacing “d” with “f”
Save again
Open up Bambu Studio and open up your custom filaments and find the filament you copied originally (you will have two identical ones now so in this example we’re looking for the original X1 version - important it’s the original one.
click edit
now click add new preset
Like magic you can select your new filament you created oon the new machine
Boom!
Why this is a lot more involved than most examples is this will make your filament unique, retain all your custom settings tied to the other presets (shared info), will sync with the cloud and be backed up and removes the duplicate entries by binding it to the original
You will need to make a new k value setting for the new filament too
Note if you’ve made a custom printer profile as long as you created it based on the default the filament will share cross printer profiles once you bind it in the presets
Thanks most helpful.
been looking for a while
Thank you!
I migrated all of my filaments from my H2D to my H2C following your directions. To make it a bit less work, I copied the Base folder to my desktop, then used ChatGPT’s Codex app with this prompt:
”in this folder there a .json files for filament profiles for my bambu lab H2D for bambu studio. I want to use them for my H2C. I need you to rename all of the files that have H2D in the name and replace H2D with H2C. also, in the .json files, there are 3 lines that have H2D in them and I need that H2D replaced with H2C. one final thing. in all of the Json files, there’s a line that wil look something like this ““filament_id”: “P9f8d8cf”” and each file will have a unique 8 letter/number code. in each file you modify, i need you to change the ID to be unique by changing one of the letters or numbers. for example: “filament_id”: “P9f8d7cf”“
It made short work of it. then I copied the new .json files back into the original base folder and reopened bambu studio and they were all there and integrated.
