P1P Versions
I have three P1P’s.
One has an AMS attached the other two do not.
The AMS P1P is on version 01.00.00.00 (AMS version 00.00.04.36)
The other two P1P’s are on version 01.02.02.00
Also the screen on the P1P with AMS is different than the others. When I go to WLAN it displays my IP and SSID, the other two show SSID, choice of LAN only mode, IP and access code.
Can someone explain what is happening. I am stumpped.
Thanks
Your AMS P1P is not upgraded to the current firmware version 01.02.02.0. If you want this, try to check it on the newest version of Bambu Studio. Maybe, you have to disconnect the AMS. I have no AMS, so I can check this. My P1P should the existing Upgrade on power on. If you have the P1P running all time, maybe you should power off and on again.
Go into Bambu studio, device tab. Select the printer with the AMS. Go to update on the left hand side. It should show an update available.
Thanks, I had to disconnect the AMS, factory reset, power off, and then the update appeared. Plugged the AMS back in and it to had an update.
