P1S Chamber temperature display/setting
Hello
In the FAQs about the difference of the P1P and P1S could be read " a Chamber Regulator Fan to stabilize the inner chamber temperature" is present in the P1S. So if something is regulating the chamber temperature I would guess the temperature has to be measured. If so, why will it nor be displayed in the display of the printer and in bambo studio, and why could the temperature not be set in the device-options ?
Your guess would be wrong.
You enable the chamber fan and it’s speed (as a percentage) in the filament settings menu and it’s purely based upon the bed temperatures setting.
Ok, thank you for that information. So there is no regulation. Just a fan for a more even spreading of the temperature in the chamber. Even something more that should be written in the FAQ “What is the difference between P1S and X1C”.
The X1C doesn’t use its sensor to regulate the temperature either, it’s only used to display it on the screen. Someone mentioned that the X1E uses it along with the heater to do some regulating. There’s very cheap temperature switched fan controllers available which you can use to do this if you want. You would only need to make a housing and splice into the chamber fan wiring
https://amzn.asia/d/9CnVoVU
Can you explain better this configuration? in this mode is it possible to modulate the fan speed or can you just turn it on and off?
Tks
These are simple fan controllers which have a hysteresis for the on and off, so once the temperature you set is reached, it will stay on until it reaches the set off temperature. I don’t believe they will alter the fan speed to control the temperature. But this could be done with other controllers.
Seems like a big oversight on the side of Bambu Lab. Is there anyway to connect a temperature sensor for the chamber? I see it has it in Bambu Studio so I would think it has some kind of interface for retrofitting this.
Welcome to the forum.
I don’t think it was an oversight, more a that “lower end” models shouldn’t have as many features as higher end models.
The best I can suggest is to put a temperature display sensor in the chamber, in view of the camera. Works great on my P1S.
Thank you for the suggestion! May I ask — doesn’t the print head sometimes bump into the thermometer when it’s placed inside the chamber?
