P2S External exhaust fan kit - Experiences?
Have bought that kit and printed the housing in PETG.
After removing the supports, and trying to fix one of the claws on the top cover, i recognizes that the claw did not go that deep into the top cover that it was aligned to be on same level as the top cover (not the hook, only the part which goes into the space in the top cover).
So i spent some time to reduce more residuals from the supports… maybe too much, not sure. Sometimes it is hard to distinguish end of support and start of real body.
Whatever, i now ended up with a nice fitting housing on the printer, but when i did try to remove the housing from the printer to add a activated carbon filter into the housing, i had some hard time to remove the housing from the printer again. No way to simply push the housing to the side, i really needed to hit very hard on the side to get it moved over to the release position.
So i am wondering now… did i remove too much of support and therefore the claws are sitting too tight… or does everybody else here with the fan kit makes the same experience ?
i have also had issues with the claws, I printed them in PETG and when I wanted to remove them, they snapped.
