I’m running a Bambu P2S with a 0.6mm hotend/nozzle, printing Bambu PLA Basic at 0.3mm layer height (standard 0.30mm preset as base). Filament case from maker makerworld.
Main issues:
• Nozzle dragging/scraping noise on infill during travels (audible clunk/scrape, visible scrape marks in recessed flat areas and some ooze trails on top/rim).
• Increased stringing
• Prints have blobs/zits opposite clip features, but those mostly resolved.
What I’ve already done/fixed:
• Manual flow calibration (flow ratio now 0.98).
• Replaced/trimmed PTFE tube back to full length, lubed motion system and chain.
• Undid some cable chain clips to reduce drag.
• Z-hop enabled at 0.6mm, reduce infill retraction OFF, travel distance threshold 1mm. Tried different infill patterns
• Wipe while retracting ON (wipe distance 1mm), retraction 1mm @ 55mm/s.
• Avoid crossing wall ON, Arachne wall generator, aligned seam + smart scarf.
• Outer/inner walls at 500-600mm/s (stock high), top surface 150mm/s.
• Filament dry, aux fan 100%.
I also had some abysmal gridfinity bins that looked like someone tried to shove them through a paper shredder.
Do the .6 high flow hotends suck or are the profiles just that bad? What’s been your experience? I have yet to get a good print out of it. Using the .24 layer height preset reduces but does not solve the problem. I’m about to lose my mind, I feel like I’m sweeping the ocean.
