Is there a low power mode to bring the heatbed under control for multi printer setups? I know my H2D’s got it now and it was a life saver. What about the P2S or the new X2C? Not sure which one to buy atm and I need to replace 5 P1S’s that are on a 20 amp 120V circuit. I was just about to order until I read the P2S uses crazy power on heating up.
The P2S printer has a power-saving mode, but it basically turns off the printer’s backlight and screen after a while. The shutdown time can be adjusted.
I think the H2C/H2D have dual independent bed heaters - possibly because of their bed size. Their low power mode simply disables one of the heaters. I also think the heaters are simple on/off things, no PWM regulation or anything. And finally I think the smaller printers only have one heater.
I could be wrong about most of this, for your sake let’s hope so!
I think you are wrong because my X2D also has low power mode and it has a regular bed size. It takes longer to heat the bed.
Btw, if you guys are interested in the exact numbers, I can measure the power consumption for these printers: H2C, X2D, P1S, A1, A1 mini
I think i can remenber the power saving mode that relates to the P2S bed avoids power spikes by taking longer to heat up. The total power consumption will be the same. I believe this was written in the firmware update details.
Hi. Would you be able to test these printers in normal mode and then in Low Power Mode and show the exact numbers?
So this is for the UK 230V models. I don’t know about US 110-120V models
In normal mode:
X2D: spikes to around 1500W when heating up the bed. Then drops to 100-200W when bed reaches target temperature.
H2C: spikes to around 1900W when heating up the bed. Then drops to 100-300W when bed reaches target temperature.
In low-power mode:
X2D: spikes to around 900W when heating up the bed. Then drops to 100-200W when bed reaches target temperature.
H2C: spikes to around 400W when heating up the bed. Then drops to 100-300W when bed reaches target temperature.
On X2D, I’ve not noticed any significant delays on reaching the target bed temperature for PLA/PETG. For engineering materials, the chamber heating/bed temperatures are slightly slower, probably by a minute or so. So for a similar size printer like P2S it should behave the same.
On H2C, there is a significant delay on reaching target bed temperature even for PLA and PETG. This is probably due to only using one of the two bed heaters (judging by the 400W peak power). It takes probably 2-3 minutes more to reach 70 degrees for PETG. I haven’t tested engineering materials yet, but based on the X2D numbers, it’ll probably take 5-8 minutes longer.
My suggestion is:
Put small printers on low power mode as it doesn’t really affect the bed heating times that much. For large printers, don’t use low-power mode unless you have to. The time difference is quite large.
