P2S: Pause does not work during setup phase
The pause operation does not work while the printer is in the setup phase. While bed levelling I noticed an obstacle on the print bed, but pause would not stop the levelling sequence, it paused when the levelling was completed, however, by that time the obstacle had been touched.
Totally normal and also can’t be changed.
Printer controllers operate in realtime, they perform one task at a time before moving on to the next task.
Usually tasks are very small - printing movements are broken up into curve, arc, or line segments, but bed probing is a single command that the printer executes as a block before moving onto the next command.
There is always the option to abort the project via the Stop button. The project is still intact.
I occasionally will have to do that because a variety of things from like your example up through maybe I wanted to put some text on the object and forgot to, or decided I want to beef up the infill for example.
uhh, yep. Mine too.
But if you really get desperate there is a switch around back that can shut off the power. That’ll stop it.
Yep. You can always run to your fuse panel and shut off the master switch to the entire house.
That’ll do it.
Cable spiker is totally the way to go.
The ability to stop a manual Load or Unload sequence would be nice. So many times I’ve hit the wrong button…
I have a better idea…
200w
But then you’d have to reset all the clocks… :rofl:
Yeah got me there. All fairness, I dont think I have a clock in my house that is not connected to a computer in some sort, except my oven.
The ones that irk me are the oven and the microwave. One right over the other. I set one to 12-hour and the other to 24-hour. Makes the situation more Worldly.
And convinces people I really am quite weird. :zany_face: (And still PO’d about a near new spool loss.)
I absolutely haaaaaaaate those buttons being single-press.
