I wanted to share my experience with Bambu’s PA6-GF filament. The default profile (100 °C bed, 65 °C chamber) runs too hot in my testing. Prints barely held on the smooth plate with glue and showed noticeable warping. On the textured plate, adhesion failed completely, even with glue.
I opened a support case with Bambu before going down this path, but the response was that the material is simply prone to warping. Unfortunately, the possibility that the default temps might be the issue was ignored after bringing up multiple times.
After experimenting, I found a simple fix:
• Bed: 50 °C
• Chamber: 50 °C
No other changes were needed to the default profile. With these temps, adhesion is excellent on both the textured and smooth plates with glue. No warping, no detaching, and parts stay firmly attached even hours after printing finishes.
Hopefully the Bambu team can review the default RFID profile for this filament. The material performs great once temperatures are dialed in.
I really like the RFID system Bambu uses, but it doesn’t currently allow tuning for cases like this. And based on what I’ve seen across forums and groups, I’m definitely not the only one running into PA6-GF issues out of the box.
100/60 worked with glue for me.
50/50 worked with just aquanet.
I tried the default 100/60 with aquanet, and everything slipped at around layer 30. You’ll also have more success if you print only one item at a time.
Hey, I just started playing with the Bambu PA6-GF and had similar issues with it sticking to the texture PEI plate.
Drying - dried with Eibos dryer PA setting for 8 hours (right out of the bag) and then in the AMS2 on the PETG setting for 10 hours.
Plate - Bambu PEI Textured cleaned with isopropyl (91) and a blue shop towel - this works great for PETG
Test 1 Stock settings on X1C .4mm nozzle - dynamic flow immediately peeled up and I stopped the print
Test 2 heat bed bumped up 5C - same problem but slightly better
Test 3 heat bed 115C Chamber 45C Nozzle 275C - dynamic flow finally stuck, the square I printed peeled on a corner after the first layer and when the inspection finished and printing resumed, it promptly stuck to the nozzle
I cleaned my plate in between each test and after test 3 I cleaned and printed PETG with no issues
Test 4 same heat settings and added the purple glue stick to all the plate - print finally stuck really good.
This does not seem very optimal. I will give the lower temp setting a try once I clean all the glue off the plate.
