With the Amazon Prime Sale I purchased the Panda Breath v1.1 that works with the P2S. I am going thru their Github and getting all the files for the riser. I noticed that their is not a cable clamp for the P2S riser. Do I use the one from the P1S files?
I am going to print mine in ASA. Any tips or suggestions?
They look identical, so I would say yes. In any case BTT provided a step file for P1S riser, so you can adjust for P2S, if P1S doesn’t fit.
Yes, don’t print in ASA. Print in PETG.
There are several reasons why:
ASA/ABS shrink a lot, so tolerances may be an issue.
Without a hot chamber, there is a high chance of them warping (even with heated chamber ASA can warp, because parts a thin and long. That’s pretty much the worst case).
Temperature-wise - PETG is sufficient for a riser.
OK thank you for the input. I will use PETG instead of ASA.
ASA would be fine assuming you are already experienced with it and have it dialed in.
PETG would just be a lot easier.
But yeah, I have to agree with Advocado, ASA is overkill for a riser.
Looks like there is also a mounting bracket in the STLs files for the P2s. Presumably that is to hold the actual unit itself. Would folks suggest to print that in ABS?
Yeah, just because of the close proximity to the heater.
