Hi All,
I’ve got hold of some of this filament.
Any advice as to how best print it?
I note that BL make a lot of noise about drying out before use.
Gerard
Hi All,
Gerard
Dry it, lots of user have posted that hey had bad prints until they were told to dry it…then they had good prints.
I dried my overnight, cause why not…I was sleeping anyway.
Most importantly, weigh your filament and write down its weight on the spool so you know the starting value when it comes out of the bag. Then, dry it while checking the weight every 2-4 hours. Over time, it will stop losing weight, which indicates that all the moisture has been removed. Record the final weight on the spool along with the amount of moisture lost. This will show you exactly how much moisture was present in the filament.
A noteworthy point: 1g = 1cc = 1ml of water. I’ve had 1kg spools that contained as much as 13g of moisture. However, in fairness, I couldn’t determine how much of that moisture came from the filament versus the cardboard spool in that case. For Bambu spools, since they are plastic, this concern does not apply.
Thanks for the good information.
I’ve invested in a dryer that will dry 2 spools at a time.
My electricity tariff is 1/2 price overnight so I can take advantage of that.
I’ll post up some pics when I get cranked up.
My dryer is an epic failure as it cannot go higher than 50C!
It will just take longer to dry.
What dryer did you by…??
It doesn’t get hotter than 47C (I recorded that later) and I ran it overnight…10 hours.
There was no change in the mass I recorded before I put it in. Not even 1g!
It’s a Comgrow
That could also mean that there wasn’t any moisture present at the start of the cycle. This is why it’s so important to measure right out of the bag and right after drying.
However, I can totally understand that one may have doubts. When I did, I would place it in my kitchen oven at 140F/60C. I’d measure it at two hour intervals. At 60C, it should be more than enough to force any moisture to evaporate. But be careful to monitor the oven… lest you have one of these beauties for your hall of shame trophy case.
This was a spool of PETG. At 60C it worked great in my oven, so why not 85C??? Sure… that’s the ticket… except the spool wasn’t rated for that. I keep this around as a humble reminder. ![]()
Actually, I didn’t think of zero moisture!
I have put the filament in the oven at 63C. Let it run for several hours and redo the weight test.
Similar to your pic, I pretty much did that with one of the BL spools rated to 70C. I had it in a small oven where you could set the temp. I figured 65C. What I did not count on was the oven runs about 10% hotter than indicated. So, just north of 70C and it was goodbye to the spool!
The results of drying were pretty consistent.
Being cooked at 63C for 10 hours showed little reduction in mass. About 4g per spool. Say, for example, 1278g >1274g.
I’m going to give it a try now and we’ll see the ‘proof of the pudding’ so to speak/
That’s .4% and for PETG that is saturated. Maybe PETG-HF can soak up more, but that sounds like a lot to me. Sometimes hard to know with the spool in the equation also.
What I failed to mention was that I measured the mass (weighed on a scale) several times and the loss of mass was a fair bit to start with and tapered off as time went on. Like Newton’s Law of Cooling.
May I ask what you use to dry it ? I’m getting a X1C this week and I found out it has a program to dry the PETG in the printer.
I use Sunlu S2 & Creality Space Pi filament dryers.
That’s exactly how it should go. The problem with weights is if you don’t get a weight change it doesn’t explain why. But since you got 4g out (I saw just over 2g on the PETG HF I weighed while drying) you probably did well.
Since your prints are looking good, if you are happy with them you’re done. The thing about drying is you really only need to dry enough to get good results. (Though the drier you get it the more headroom you have from reabsorbing moisture and moving back into moisture problems.) I don’t know if you can remove too much water but you can overheat your filament.
Do you know if any of those two works better for PETG-HF ?
Either of them will work, they each have their plus’ & minus’.
Space Pi, has a powerful fan, but sucks on cardboard spools (Dust Storm), will dry faster.
S2, new units have a weak fan (mine doesn’t have a fan), will dry slower.
They are about the same price, so the choice is yours.
Whichever way you go, have a look over in MakerWorld to see if there are door props that you can print available.
If you watch the humidity in the dryer, it does kind of the mirror image of the filament weight as moisture leaves. Just like how weight decreases initially pretty fast, the humidity in filament dryers spikes. And how the weight change gets smaller and smaller, the humidity in the dryer will start to come back down provided enough ventilation and time.
Helping that humidity out by propping the door open a little can help speed up drying.
