Hello everyone,
I urgently need your help with a printing issue using Bambu Lab PETG Basic on my X1-C printer.
Hardware:
• Bambu Lab X1-C
• PEI print bed (first layer is perfect)
• Bambu PETG Basic
Object:
A box including a logo with dimensions of 160mm x 220mm x 60mm.
Print Profile:
0.20mm Standard @ BBL X1C
Issue Description:
Unfortunately, I am facing difficulties in achieving a successful print. The problems manifest as follows:
• The infill does not adhere correctly, resulting in numerous gaps.
• The wall layers are partially not connecting to each other.
Steps Taken So Far:
I have already tried several measures to address the problem, but unfortunately, without success:
• I left the printer enclosure door open.
• The nozzle has been cleaned, including a “cold pull.”
• I changed the infill pattern from grid to gyroid.
• The X1-C has been calibrated multiple times.
• I disabled the “slowing down for overhangs” option and increased the bridging speed to 200 mm/s.
• I dried the filament spool using the X1-C’s drying function overnight.
I only have experience with PLA so far, so I am currently a bit desperate. I am aware that PETG requires different printing settings than PLA. Nevertheless, it should be possible to achieve a successful print using the X1-C and the in-house filament, right? Or am I mistaken?
I would greatly appreciate it if you could help me troubleshoot this issue!
Thank you in advance for your assistance!
