Great for a bedslinger. Wash you’re plate.
And your hands, they’re filthy
Meh, I just wipe it down with hand sanitizer
ah, but the sanitizer is filthy too. Wash that as well…
When I zoom in on the original images, it looks like a classic case of failed automatic bed leveling. In the low areas the gaps between the extruded lines are large enough that I can see straight through to the bed underneath. FAIL. If it were that way everywhere then it might be simple under-extrusion that could be corrected through calibration, but it IS NOT that way everywhere.
Maybe it looks different in real life than it does in the photos, but that’s how it looks to me based on the images you have provided. To better confirm, I recommend you peel it off the bed and then post a photograph of it with a light behind it. It should be a solid mass, not look all stringy, like something vaguely resembling a venetian blind of sorts. By that I mean there should NOT be obvious air gaps between any of the extruded lines.
It seems to do multi color really well! Bambu spools in the Ace roll like a dream compared to the Anycubic cardboard spools even with the printed spool lips.
Wasn’t thinking when I colored this, could a saved a couple hours and a lot of flush putting the wings on a separate plate, or perhaps print by object?
Print by object would have saved filament and time. Either way it looks good.
Can we see you ?
Fouchvkuvkuvkuvvvv
Bobby, what in the h…
He looks stoned
I couldn’t be bothered to work out how to deal with 25 characters and didn’t spot the trick.
So I was a monkey hitting keys on my iPad.
Why didn’t you say so. I thought I sent it in a message to you.
Hold on, no more iPads need to be assulted.
@CRracer712 The only thing I am going to do is ask you a question. Why on Earth are you coming to the Bambu Lab Community Forum, and asking us Bambu owners what’s wrong with your non-Bambu printer?
P.s. Sorry if I came across as rude, it’s 9:13 PM where I am right now, and I’ve been up since about 6:30 AM, so i’m a “little” tired right now.
Test
Holy yap-a-tron. Also, you are kind of wrong. His problem is clearly that he didn’t buy a Bambu, and there is nothing wrong with bedslingers (as long as they are made by Bambu Lab)
I guess you’ve not ventured into the latest Bambu speculation thread where there’s multiple brands of printers brought up and even tests ran on them
This is the ‘other’ forum. I own two Bambu printers, I hope that makes it ok if printer peeps talk printers.
Meh, fair enough. As I’ve said, I am a bit tired right now, so I’m not really thinking about things as much as I normally do.
Just so you know, there’s wide spread speculation you were replying to AI @Hank
Are you talking to me or @Hank?
You
I don’t get what you mean by
Can you please elaborate?
