Hello,
i have the exhaust fan installed.
Now i woulf like to connect 4pin Bus devices and bought the H2 4pin interface board.
i know the pinout of the 4pin internal connector if the H2 interface board.
on the exhaust fan board is an internal 4pin connector. i think this is for internal bus connection,
does anybody know the pinout of that 4pin connector of the exhaust fan board?
i can only find ground
I would think the internal would mimic the printer side, however this will give you a start as only 2 are swapped in the 4 pin.
https://www.reddit.com/r/BambuLab/comments/1374wbd/access_24v_in_the_bambu_bus_cable_4pin/
That pinout ist known.
I thought i can connect both board with the internal connectors.
But i cant Figuren out the pinout of the connector on the exhaust fan board
I think the best thing would be to put in a ticket to be sure. The rotary uses that port but I don’t know if the pin out is available or the same.
@SupportAssistant is this possible to help with?
I am not sure if I understand the question correctly.
But yes, it’s best to open a ticket and ask for help. Please make sure that you include details of what you wish to achieve, so that our team can provide the best suggestions.
Thanks!
Support wont help because it is a secret.
i just wanted to use the h2 interface board as an adapter for using my 4pin bus devices.
the h2 interface board pinout is easy (VCC, GND and SIgnal A & B) are on that internal 4pin connector. But on the ehaust board i can only find GND.
