POLL: Bambu Lab Please provide a complete list of error codes
  • I want Bambu Lab to provide a complete list of ALL possible error and warning codes that any version of any printer’s firmware can emit.
0 voters
Be good if it just displayed the error in plain language rather than a code.
Preferably both. Keeping in mind that they have to support many languages, and there can be translation errors.
I am sure there are a lot of BBL-users that will help provide translations……
:slight_smile:
The fact that they are not all documented is my big issue. I even suggested to BBL that they could just extract the list from their code automatically and post the raw list. You know they are all in a single file to allow translation. They actually responded saying they did not want to release all possible error codes.
I am going to post all the codes here from the file in three or four posts. Remove the underscores from the message on the printer to search. Hopefully it works. As outlined already, its a dump of the most recent hms_en.json file from my PC. (6/29/2023).
03000D0000010008 The build plate is not placed properly. Please adjust it.
03000D0000010009 The build plate is not placed properly. Please adjust it.
03000D000001000A The build plate is not placed properly. Please adjust it.
03000D0000020001 Heatbed homing abnormal. There may be a bulge on the heated bed or the nozzle tip is not clean.
03000F0000010001 The accelerometer data is unavailable. The communication connection to the tool head may be broken, or the accelerometer may be damaged.
0300100000020001 The resonance frequency of the X axis is low. The timing belt may be loose.
0300110000020001 The resonance frequency of the Y axis is low. The timing belt may be loose.
0300120000020001 The front cover of the toolhead fell off.
0500010000020001 The media pipeline is malfunctioning.
0500010000020002 USB camera is not connected. Please check video camera cable connection.
0500010000020003 USB camera is malfunctioning.
0500010000030004 Not enough space in MicroSD Card, please clear some space.
0500010000030005 MicroSD Card error: please reinsert, format or replace it.
0500010000030006 Unformatted MicroSD Card: please format it.
0500020000020001 Failed to connect internet. Please check the network connection.
0500020000020002 Device login failed; please check your account information.
0500020000020003 Failed to connect internet; please check the network connection.
0500020000020004 Unauthorized user: please check your account information.
0500020000020005 Failed to connect internet; please check the network connection.
0500020000020006 Liveview service is malfunctioning; please check your network connection.
0500020000020007 Liveview service login failed; please check your network connection.
0500030000010001 The MC module is malfunctioning; please restart the device or check device cable connection.
0500030000010002 The toolhead is malfunctioning. Please restart the device.
0500030000010003 The AMS module is malfunctioning. Please restart the device.
0500030000010004 Internal communication is malfunctioning. Please restart the device.
0500030000010005 Internal service is malfunctioning. Please restart the device.
0500030000010006 A system panic occurred. Please restart the device.
0500030000010008 A system hang occurred. Please restart the device.
0500030000010009 A system hang occurred. It has been recovered by automatic restart.
050003000001000a System state is abnormal; please restore factory settings.
050003000001000b The screen is malfunctioning; please restart the device.
050003000002000c Wireless hardware error: please turn off/on WiFi or restart the device.
050003000002000d The SD Card controller is malfunctioning.
0500030000030007 A system panic occurred. It has been recovered by automatic restart.
0500040000010001 Failed to download print job. Please check your network connection.
0500040000010002 Failed to report print state. Please check your network connection.
0500040000010003 The content of print file is unreadable. Please resend the print job.
0500040000010004 The print file is unauthorized.
0500040000010006 Failed to resume previous print.
0700010000010001 The AMS1 assist motor has slipped. The extrusion wheel may be worn down, or the filament may be too thin.
0700010000010003 The AMS1 assist motor torque control is malfunctioning. The current sensor may be faulty.
0700010000010004 The AMS1 assist motor speed control is malfunctioning. The speed sensor may be faulty.
0700010000020002 The AMS1 assist motor is overloaded. The filament may be tangled or stuck.
0700020000010001 AMS1 Filament speed and length error: The filament odometry may be faulty.
0700100000010001 The AMS1 slot1 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0700100000010003 The AMS1 slot1 motor torque control is malfunctioning. The current sensor may be faulty.
0700100000020002 The AMS1 slot1 motor is overloaded. The filament may be tangled or stuck.
0700110000010001 The AMS1 slot2 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0700110000010003 The AMS1 slot2 motor torque control is malfunctioning. The current sensor may be faulty.
0700110000020002 The AMS1 slot2 motor is overloaded. The filament may be tangled or stuck.
0700120000010001 The AMS1 slot3 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0700120000010003 The AMS1 slot3 motor torque control is malfunctioning. The current sensor may be faulty.
0700120000020002 The AMS1 slot3 motor is overloaded. The filament may be tangled or stuck.
0700130000010001 The AMS1 slot4 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0700130000010003 The AMS1 slot4 motor torque control is malfunctioning. The current sensor may be faulty.
0700130000020002 The AMS1 slot4 motor is overloaded. The filament may be tangled or stuck.
0700200000020001 AMS1 Slot1 filament has run out. Please insert a new filament.
0700200000020002 AMS1 Slot1 is empty; please load a new filament.
0700200000020003 AMS1 Slot1’s filament may be broken in AMS.
0700210000020001 AMS1 Slot2 filament has run out. Please insert a new filament.
0700210000020002 AMS1 Slot2 is empty; please load a new filament.
0700210000020003 AMS1 Slot2’s filament may be broken in AMS.
0700220000020001 AMS1 Slot3 filament has run out. Please insert a new filament.
0700220000020002 AMS1 Slot3 is empty; please load a new filament.
0700220000020003 AMS1 Slot3’s filament may be broken in AMS.
0700230000020001 AMS1 Slot4 filament has run out. Please insert a new filament.
0700230000020002 AMS1 Slot4 is empty; please load a new filament.
0700230000020003 AMS1 Slot4’s filament may be broken in AMS.
0700300000010001 The RFID board between AMS1 Slot1 & Slot2 has an error.
0700300000010004 Encryption chip failure.
0700300000020002 The RFID-tag on AMS1 Slot1 is damaged.
0700300000030003 RFID cannot be read because of a hardware or structural error.
0700310000010001 The RFID board between AMS1 Slot3 & Slot4 has an error.
0700310000010004 Encryption chip failure.
0700310000020002 The RFID-tag on AMS1 Slot2 is damaged.
0700310000030003 RFID cannot be read because of a hardware or structural error.
0700320000020002 The RFID-tag on AMS1 Slot3 is damaged.
0700330000020002 The RFID-tag on AMS1 Slot4 is damaged.
0700350000010001 The temperature and humidity sensor has an error. The chip may be faulty.
0700400000020001 The filament buffer position signal lost: the cable or position sensor may be malfunctioning.
0700400000020002 The filament buffer position signal error: the position sensor may be malfunctioning.
0700400000020003 The AMS Hub communication is abnormal, the cable may be not well connected.
0700450000020001 The filament cutter sensor is malfunctioning; please check whether the connector is properly plugged in.
0700450000020002 The filament cutter’s cutting distance is too large. The XY motor may lose steps.
0700450000020003 The filament cutter handle has not released. The handle or blade may be stuck.
0701010000010001 The AMS2 assist motor has slipped. The extrusion wheel may be worn down, or the filament may be too thin.
0701010000010003 The AMS2 assist motor torque control is malfunctioning. The current sensor may be faulty.
0701010000010004 The AMS2 assist motor speed control is malfunctioning. The speed sensor may be faulty.
0701010000020002 The AMS2 assist motor is overloaded. The filament may be tangled or stuck.
0701020000010001 AMS2 Filament speed and length error: The filament odometry may be faulty.
0701100000010001 The AMS2 slot1 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0701100000010003 The AMS2 slot1 motor torque control is malfunctioning. The current sensor may be faulty.
0701100000020002 The AMS2 slot1 motor is overloaded. The filament may be tangled or stuck.
0701110000010001 The AMS2 slot2 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0701110000010003 The AMS2 slot2 motor torque control is malfunctioning. The current sensor may be faulty.
0701110000020002 The AMS2 slot2 motor is overloaded. The filament may be tangled or stuck.
0701120000010001 The AMS2 slot3 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0701120000010003 The AMS2 slot3 motor torque control is malfunctioning. The current sensor may be faulty.
0701120000020002 The AMS2 slot3 motor is overloaded. The filament may be tangled or stuck.
0701130000010001 The AMS2 slot4 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0701130000010003 The AMS2 slot4 motor torque control is malfunctioning. The current sensor may be faulty.
0701130000020002 The AMS2 slot4 motor is overloaded. The filament may be tangled or stuck.
0701200000020001 AMS2 Slot1 filament has run out. Please insert a new filament.
0701200000020002 AMS2 Slot1 is empty; please load a new filament.
0701200000020003 AMS2 Slot1’s filament may be broken in AMS.
0701210000020001 AMS2 Slot2 filament has run out. Please insert a new filament.
0701210000020002 AMS2 Slot2 is empty; please load a new filament.
0701210000020003 AMS2 Slot2’s filament may be broken in AMS.
0701220000020001 AMS2 Slot3 filament has run out. Please insert a new filament.
0701220000020002 AMS2 Slot3 is empty; please load a new filament.
0701220000020003 AMS2 Slot3’s filament may be broken in AMS.
0701230000020001 AMS2 Slot4 filament has run out. Please insert a new filament.
0701230000020002 AMS2 Slot4 is empty; please load a new filament.
0701230000020003 AMS2 Slot4’s filament may be broken in AMS.
0701300000010001 The RFID board between AMS2 Slot1 & Slot2 has an error.
0701300000010004 Encryption chip failure.
0701300000020002 The RFID-tag on AMS2 Slot1 is damaged.
0701300000030003 RFID cannot be read because of a hardware or structural error.
0701310000010001 The RFID board between AMS2 Slot3 & Slot4 has an error.
0701310000010004 Encryption chip failure.
0701310000020002 The RFID-tag on AMS2 Slot2 is damaged.
0701310000030003 RFID cannot be read because of a hardware or structural error.
0701320000020002 The RFID-tag on AMS2 Slot3 is damaged.
0701330000020002 The RFID-tag on AMS2 Slot4 is damaged.
0701350000010001 The temperature and humidity sensor has an error. The chip may be faulty.
0702010000010001 The AMS3 assist motor has slipped. The extrusion wheel may be worn down, or the filament may be too thin.
0702010000010003 The AMS3 assist motor torque control is malfunctioning. The current sensor may be faulty.
0702010000010004 The AMS3 assist motor speed control is malfunctioning. The speed sensor may be faulty.
0702010000020002 The AMS3 assist motor is overloaded. The filament may be tangled or stuck.
0702020000010001 AMS3 Filament speed and length error: The filament odometry may be faulty.
0702100000010001 The AMS3 slot1 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0702100000010003 The AMS3 slot1 motor torque control is malfunctioning. The current sensor may be faulty.
0702100000020002 The AMS3 slot1 motor is overloaded. The filament may be tangled or stuck.
0702110000010001 The AMS3 slot2 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0702110000010003 The AMS3 slot2 motor torque control is malfunctioning. The current sensor may be faulty.
0702110000020002 The AMS3 slot2 motor is overloaded. The filament may be tangled or stuck.
0702120000010001 The AMS3 slot3 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0702120000010003 The AMS3 slot3 motor torque control is malfunctioning. The current sensor may be faulty.
0702120000020002 The AMS3 slot3 motor is overloaded. The filament may be tangled or stuck.
0702130000010001 The AMS3 slot4 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0702130000010003 The AMS3 slot4 motor torque control is malfunctioning. The current sensor may be faulty.
0702130000020002 The AMS3 slot4 motor is overloaded. The filament may be tangled or stuck.
0702200000020001 AMS3 Slot1 filament has run out. Please insert a new filament.
0702200000020002 AMS3 Slot1 is empty; please load a new filament.
0702200000020003 AMS3 Slot1’s filament may be broken in AMS.
0702210000020001 AMS3 Slot2 filament has run out. Please insert a new filament.
0702210000020002 AMS3 Slot2 is empty; please load a new filament.
0702210000020003 AMS3 Slot2’s filament may be broken in AMS.
0702220000020001 AMS3 Slot3 filament has run out. Please insert a new filament.
0702220000020002 AMS3 Slot3 is empty; please load a new filament.
0702220000020003 AMS3 Slot3’s filament may be broken in AMS.
0702230000020001 AMS3 Slot4 filament has run out. Please insert a new filament.
0702230000020002 AMS3 Slot4 is empty; please load a new filament.
0702230000020003 AMS3 Slot4’s filament may be broken in AMS.
0702300000010001 The RFID board between AMS3 Slot1 & Slot2 has an error.
0702300000010004 Encryption chip failure.
0702300000020002 The RFID-tag on AMS3 Slot1 is damaged.
0702300000030003 RFID cannot be read because of a hardware or structural error.
0702310000010001 The RFID board between AMS3 Slot3 & Slot4 has an error.
0702310000010004 Encryption chip failure.
0702310000020002 The RFID-tag on AMS3 Slot2 is damaged.
0702310000030003 RFID cannot be read because of a hardware or structural error.
0702320000020002 The RFID-tag on AMS3 Slot3 is damaged.
0702330000020002 The RFID-tag on AMS3 Slot4 is damaged.
0702350000010001 The temperature and humidity sensor has an error. The chip may be faulty.
0703010000010001 The AMS4 assist motor has slipped. The extrusion wheel may be worn down, or the filament may be too thin.
0703010000010003 The AMS4 assist motor torque control is malfunctioning. The current sensor may be faulty.
0703010000010004 The AMS4 assist motor speed control is malfunctioning. The speed sensor may be faulty.
0703010000020002 The AMS4 assist motor is overloaded. The filament may be tangled or stuck.
0703020000010001 AMS4 Filament speed and length error: The filament odometry may be faulty.
0703100000010001 The AMS4 slot1 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0703100000010003 The AMS4 slot1 motor torque control is malfunctioning. The current sensor may be faulty.
0703100000020002 The AMS4 slot1 motor is overloaded. The filament may be tangled or stuck.
0703110000010001 The AMS4 slot2 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0703110000010003 The AMS4 slot2 motor torque control is malfunctioning. The current sensor may be faulty.
0703110000020002 The AMS4 slot2 motor is overloaded. The filament may be tangled or stuck.
0703120000010001 The AMS4 slot3 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0703120000010003 The AMS4 slot3 motor torque control is malfunctioning. The current sensor may be faulty.
0703120000020002 The AMS4 slot3 motor is overloaded. The filament may be tangled or stuck.
0703130000010001 The AMS4 slot4 motor has slipped. The extrusion wheel may be malfunctioning, or the filament may be too thin.
0703130000010003 The AMS4 slot4 motor torque control is malfunctioning. The current sensor may be faulty.
0703130000020002 The AMS4 slot4 motor is overloaded. The filament may be tangled or stuck.
0703200000020001 AMS4 Slot1 filament has run out. Please insert a new filament.
0703200000020002 AMS4 Slot1 is empty; please load a new filament.
0703200000020003 AMS4 Slot1’s filament may be broken in AMS.
0703210000020001 AMS4 Slot2 filament has run out. Please insert a new filament.
0703210000020002 AMS4 Slot2 is empty; please load a new filament.
0703210000020003 AMS4 Slot2’s filament may be broken in AMS.
0703220000020001 AMS4 Slot3 filament has run out. Please insert a new filament.
0703220000020002 AMS4 Slot3 is empty; please load a new filament.
0703220000020003 AMS4 Slot3’s filament may be broken in AMS.
0703230000020001 AMS4 Slot4 filament has run out. Please insert a new filament.
0703230000020002 AMS4 Slot4 is empty; please load a new filament.
0703230000020003 AMS4 Slot4’s filament may be broken in AMS.
0703300000010001 The RFID board between AMS4 Slot1 & Slot2 has an error.
0703300000010004 Encryption chip failure.
0703300000020002 The RFID-tag on AMS4 Slot1 is damaged.
0703300000030003 RFID cannot be read because of a hardware or structural error.
0703310000010001 The RFID board between AMS4 Slot3 & Slot4 has an error.
0703310000010004 Encryption chip failure.
0703310000020002 The RFID-tag on AMS4 Slot2 is damaged.
0703310000030003 RFID cannot be read because of a hardware or structural error.
0703320000020002 The RFID-tag on AMS4 Slot3 is damaged.
0703330000020002 The RFID-tag on AMS4 Slot4 is damaged.
0703350000010001 The temperature and humidity sensor has an error. The chip may be faulty.
0C00010000010001 The Micro Lidar camera is offline. Please check the hardware connection.
0C00010000010003 Synchronization between the Micro Lidar camera and MCU is abnormal. Please restart your printer.
0C00010000010004 The Micro Lidar camera lens seems to be dirty. Please clean the lens.
0C00010000010005 Micro Lidar camera OTP parameter is abnormal. Please contact after-sales.
0C00010000010009 The chamber camera lens seems to be dirty. Please clean the lens.
0C00010000020002 The Micro Lidar camera is malfunctioning and related functions may fail. Please contact after-sales if this message keeps appearing in multiple prints.
0C00010000020006 Micro Lidar camera extrinsic parameters are abnormal. Please enable flowrate calibration in your next print.
0C00010000020007 Micro Lidar laser parameters are drifted. Please re-calibrate your printer.
0C00010000020008 Failed to get image from chamber camera. Spaghetti and excess chute pileup detection is not available for now.
0C00020000010001 The horizontal laser is not lit. Please check if it’s covered or hardware connection is normal.
0C00020000010005 A new Micro Lidar was detected. Please calibrate it on Calibration page before use.
0C00020000020002 The horizontal laser line is too wide. Please check if the heatbed is dirty.
0C00020000020003 The horizontal laser is not bright enough at homing position. Please clean or replace heatbed if this message appears repeatedly.
0C00020000020004 Nozzle height seems too low. Please check if the nozzle is worn or tilted. Re-calibrate Lidar if the nozzle has been replaced.
0C00020000020006 Nozzle height seems too high. Please check if there is filament residual attached to the nozzle.
0C00030000010009 The first layer inspection module rebooted abnormally. The inspection result may be inaccurate.
0C0003000001000a Your printer is in factory mode. Please contact Technical Support.
0C00030000020001 Filament exposure metering failed because laser reflection is too weak on this material. First layer inspection may be inaccurate.
0C00030000020002 First layer inspection terminated due to abnormal Lidar data.
0C00030000020004 First layer inspection is not supported for the current print job.
0C00030000020005 First layer inspection timed out abnormally, and the current results may be inaccurate.
0C00030000030006 Purged filament may have piled up in the excess chute. Please check and clean the excess chute.
0C00030000030007 Possible first layer defects have been detected. Please check the first layer quality and decide if the job should be stopped.
0C00030000030008 Possible spaghetti defects were detected. Please check the print quality and decide if the job should be stopped.
0C0003000003000b Inspecting the first layer: please wait a moment.
0300010000010006 The heatbed temperature is abnormal; the sensor may have a short circuit.
0300010000010007 The heatbed temperature is abnormal; the sensor may have an open circuit.
0300020000010006 The nozzle temperature is abnormal; the sensor may have a short circuit, please check whether the connector is properly plugged.
0300020000010007 The nozzle temperature is abnormal; the sensor may have an open circuit.
03000D000001000B The Z axis motor seems got stuck when moving up. Please check if there is any foreign matter on the Z sliders or Z timing belt wheels .
0300100000020002 The resonance frequency of the X axis differ much from last calibration. Please clean the carbon rod and rerun the machine calibration later.
0300110000020002 The resonance frequency of the Y axis differs greatly from the last calibration. Please clean the carbon rod and rerun the machine calibration later.
0C0003000002000c The build plate localization marker is not detected. Please check if the build plate is aligned correctly.
0C0001000001000A The Micro Lidar LED may be broken.
0C00020000020007 The vertical laser is not lit. Please check if it’s covered or hardware connection is normal.
0C00020000020008 The vertical laser line is too wide. Please check if the heatbed is dirty.
0C0003000003000d Some objects may have fallen down, or the extruder is not extruding normally. Please check and decide if the printing should be stopped.
0C0003000003000e Your printer seems to be printing without extruding.
0C0003000003000f Your nozzle seems to be covered with jammed or clogged material.
0300060000010003 The resistance of Motor-A is abnormal, the motor may have failed.
0300070000010003 The resistance of Motor-B is abnormal, the motor may have failed.
0300080000010003 The resistance of Motor-Z is abnormal, the motor may have failed.
0300090000010003 The resistance of Motor-E is abnormal, the motor may have failed.
0300130000010001 The current sensor of Motor-A is abnormal. This may be caused by a failure of the hardware sampling circuit.
0300140000010001 The current sensor of Motor-B is abnormal. This may be caused by a failure of the hardware sampling circuit.
03004000 Homing Z axis failed.
03004001 The printer timed out waiting for the nozzle to cool down before homing.
03004002 Mesh bed leveling failed.
03004003 Nozzle temperature malfunction.
03004004 Heatbed temperature malfunction.
03004005 The heatbreak fan speed is abnormal.
03004006 The nozzle is clogged.
03004008 The AMS failed to change filament.
03004009 Homing XY axis failed.
0300400A Mechanical resonance frequency identification failed.
0300400B Internal communication exception.
0300400C Printing was cancelled.
0300400D Resume failed after power loss.
03008000 Printing was paused for unknown reason. You can tap \Resume" to resume the print job."
03008001 Printing was paused by the user. You can tap \Resume" to resume the print job."
03008002 First layer defects were detected. If the defects are acceptable, tap \Resume" to resume the print job."
03008003 Spaghetti defects were detected. If the defects are acceptable, tap \Resume" to resume the print job."
03008004 The filament ran out. Please load new filament in Temperature/Axis and tap \Resume" to resume the print job."
03008005 Printing was paused because the front cover of tool head fell off. Please mount it back and tap \Resume" to resume the print job."
03008006 Build plate localization marker is not found, or the current build plate is not the same as in G-code. Please stop the print job and replace the build plate. You can also tap \Resume" to force resuming the print job."
05004001 Failed to connect to Bambu Cloud. Please check your network connection.
05004002 Unable to parse the received print job. Please update the firmware to the latest version and try again.
05004003 There was a problem parsing gcode.3mf. Please resend the printing job.
05004004 Printing jobs are not allowed to be sent while printing.
05004005 Print jobs are not allowed to be sent while updating firmware.
05004006 There is not enough free storage space for the print job. Restoring to factory settings can release available space.
05004007 Print jobs are not allowed to be sent while force updating or when repair updating is required.
05004008 Starting printing failed. please power cycle the printer and resend the print job.
07008001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
07008002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
07008003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
07008004 Failed to pull back the filament from the toolhead to AMS. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07008005 Failed to feed the filament outside the AMS. Please clip the end of the filament flat and check to see if the spool is stuck. After troubleshooting, click the retry button.
07008006 Failed to feed the filament into the toolhead. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07008007 Failed to extrude the filament. Please check if the extruder is clogged. After troubleshooting, click the retry button.
07008010 AMS assist motor is overloaded. Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
07008011 AMS filament ran out. Please put a new filament into AMS and click the retry button.
07018001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
07018002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
07018003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
07018004 Failed to pull back the filament from the toolhead to AMS. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07018005 Failed to feed the filament outside the AMS. Please clip the end of the filament flat and check to see if the spool is stuck. After troubleshooting, click the retry button.
07018006 Failed to feed the filament into the toolhead. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07018007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
07018010 AMS assist motor is overloaded. Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
07018011 AMS filament ran out. Please put a new filament into AMS and click the retry button.
07028001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
07028002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
07028003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
07028004 Failed to pull back the filament from the toolhead to AMS. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07028005 Failed to feed the filament outside the AMS. Please clip the end of the filament flat and check to see if the spool is stuck. After troubleshooting, click the retry button.
07028006 Failed to feed the filament into the toolhead. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07028007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
07028010 AMS assist motor is overloaded. Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
07028011 AMS filament ran out. Please put a new filament into AMS and click the retry button.
07038001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
07038002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
07038003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
07038004 Failed to pull back the filament from the toolhead to AMS. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07038005 Failed to feed the filament outside the AMS. Please clip the end of the filament flat and check to see if the spool is stuck. After troubleshooting, click the retry button.
07038006 Failed to feed the filament into the toolhead. Please check whether the filament or the spool is stuck. After troubleshooting, click the retry button.
07038007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
07038010 AMS assist motor is overloaded. Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
07038011 AMS filament ran out. Please put a new filament into AMS and click the retry button.
0C008001 First layer defects were detected. If the defects are acceptable, click resume icon to resume the print job.
0C008002 Spaghetti failure was detected.
0C00C003 Possible defects were detected in the first layer.
0C00C004 Possible spaghetti failure was detected.
03008007 There was an unfinished print job when the printer powered off. Tap \Resume" to resume the print job."
03008008 Nozzle temperature malfunction.
03008009 Heatbed temperature malfunction.
05004009 Print jobs are not allowed to be sent while updating logs.
0500400A The file name is not supported. Please rename and restart the printing job.
0300800A Purged filaments have piled up in excess chute, which may cause a tool head collision. Please clean the filament. If cleaned or acceptable, tap the resume icon to resume the print job.
0C008005 Purged filament has piled up in the excess chute, which may cause a tool head collision.
0C00C006 Purged filament may have piled up in the excess chute.
0300400E The motor self-check failed.
0300800B The cutter is stuck. Please pull out the cutter handle and click the resume button.
07008012 Failed to get AMS mapping table; please click \Retry" to continue."
07018012 Failed to get AMS mapping table; please click \Retry" to continue."
07028012 Failed to get AMS mapping table; please click \Retry" to continue."
07038012 Failed to get AMS mapping table; please click \Retry" to continue."
07008013 Timeout purging old filament: Please check if the filament is stuck or the extruder is clogged. After troubleshooting, click the retry button.
07018013 Timeout purging old filament: Please check if the filament is stuck or the extruder is clogged. After troubleshooting, click the retry button.
07028013 Timeout purging old filament: Please check if the filament is stuck or the extruder is clogged. After troubleshooting, click the retry button.
07038013 Timeout purging old filament: Please check if the filament is stuck or the extruder is clogged. After troubleshooting, click the retry button.
07004001 Filament is still loaded from the AMS after it has been disabled. Please unload the filament, load from the spool holder, and restart printing.
07014001 Filament is still loaded from the AMS after it has been disabled. Please unload the filament, load from the spool holder, and restart printing.
07024001 Filament is still loaded from the AMS after it has been disabled. Please unload the filament, load from the spool holder, and restart printing.
07034001 Filament is still loaded from the AMS after it has been disabled. Please unload the filament, load from the spool holder, and restart printing.
0500400B There was a problem downloading a file. Please check you network connection and resend the printing job.
1000C001 The bed temperature exceeds filament’s vitrification temperature, which may cause a nozzle clog. Please keep the front door of the printer open or lower the bed temperature.
1000C002 The nozzle hardness required by the filament is higher than the default nozzle hardness of the printer. Please replace with a hardened nozzle or filament. Otherwise, the nozzle will become worn down or damaged.
0500400C Please insert a MicroSD card and restart the printing job.
0500400D Please run a self-test and restart the printing job.
0300800C Skipping step detected, auto-recover complete; please resume print and check if there are any layer shift problems.
0C008009 Build plate localization marker was not found.
0500400E Printing was cancelled.
0300800D Some objects have fallen down, or the extruder is not extruding normally. If the defects are acceptable, click \Resume" icon to resume the print job."
07FF8001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
07FF8002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
07FF8003 Please remove the external filament from the extruder. If an AMS is to be used later, please connect the PTFE tube to the coupler and click the \retry" button."
07FF8004 Failed to pull back the filament from the toolhead to AMS. Please check whether the filament or the spool is stuck. After troubleshooting, click the \retry" button."
07FF8005 Failed to feed the filament outside the AMS. Please clip the end of the filament flat and check to see if the spool is stuck. After troubleshooting, click the retry button.
07FF8006 Please feed from the spool holder until the tool head filament sensor is triggered, and then click \Retry"."
07FF8007 Please observe the nozzle. If the filament has been extruded, click \Done"; if it is not please push the filament forward slightly and then click "Retry"."
07FF8010 AMS assist motor is overloaded. Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
07FF8011 AMS filament ran out. Please put a new filament into AMS and click the retry button.
07FF8012 Failed to get AMS mapping table; please click \Retry" to continue."
07FF8013 Timeout purging old filament: Please check if the filament is stuck or the extruder is clogged. After troubleshooting, click the retry button.
07FF4001 Filament is still loaded from the AMS after it has been disabled. Please unload the filament, load from the spool holder, and restart printing.
0300800E The print file is not available. Please check to see if the storage media has been removed.
0500C010 MicroSD Card error: please reinsert, format or replace it.
0500C011
05004012 The door seems to be open, so printing was paused.
05008013 The print file is not available. Please check to see if the storage media has been removed.
0300800F The door seems to be open, so printing was paused.
05004014 Failed to slice the printing job; please check the settings and restart the print job.
03008010 The heatbreak fan speed is abnormal.
07FFC003 Please remove the external filament from the extruder. If an AMS is to be used later, please connect the PTFE tube to the coupler.
07FFC006 Please feed from the spool holder until the tool head filament sensor is triggered.
05004015 There is not enough free storage space for the print job. Please format or clean MicroSD card to release available space.
12008001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
12018001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
12028001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
12038001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
12FF8001 Failed to cut the filament. Please check the cutter. After troubleshooting, click the retry button.
12008002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
12018002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
12028002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
12038002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
12FF8002 The cutter is stuck. Please pull out the cutter handle and click the retry button.
12008003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
12018003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
12028003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
12038003 Failed to pull out the filament from the extruder. Please check whether the extruder is clogged or whether the filament is broken inside extruder. After troubleshooting, click the retry button.
12FF8003 Please pull out the filament on the spool holder from the extruder. If an AMS is to be used later, please connect the PTFE tube from the AMS to the extruder and click the the retry button.
12FFC003 Please pull out the filament on the spool holder from the extruder. If an AMS is to be used later, please connect the PTFE tube from the AMS to the extruder and click the the retry button.
12008004 Failed to pull back the filament from the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12018004 Failed to pull back the filament from the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12028004 Failed to pull back the filament from the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12038004 Failed to pull back the filament from the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12FF8004 Failed to pull back the filament from the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12008005 Failed to feed the filament. Please load the filament, then click the retry button.
12018005 Failed to feed the filament. Please load the filament and then click the retry button.
12028005 Failed to feed the filament. Please load the filament, then click the retry button.
12038005 Failed to feed the filament. Please load the filament, then click the retry button.
12FF8005 Failed to feed the filament. Please load the filament, then click the retry button.
12008006 Failed to feed the filament into the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12018006 Failed to feed the filament into the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12028006 Failed to feed the filament into the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12038006 Failed to feed the filament into the toolhead. Please check whether the filament is stuck. After troubleshooting, click the retry button.
12FF8006 Please feed from the spool holder until the tool head filament sensor is triggered, and then click the retry button.
12FFC006 Please feed from the spool holder until the tool head filament sensor is triggered.
12008007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
12018007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
12028007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
12038007 Failed to extrude the filament. Please check if the extruder clogged. After troubleshooting, click the retry button.
12FF8007 Please observe the nozzle. If the filament has been extruded, click \Done"; if it is not please push the filament forward slightly and then click the retry button."
12008010 Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
12018010 Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
12028010 Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
12038010 Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
12FF8010 Please check if the spool or filament is stuck. After troubleshooting, click the retry button.
12008011 AMS filament has run out. Please insert a new filament into the AMS and click the retry button.
12018011 AMS filament has run out. Please insert a new filament into the AMS and click the retry button.
12028011 AMS filament has run out. Please insert a new filament into the AMS and click the retry button.
12038011 AMS filament has run out. Please insert a new filament into the AMS and click the retry button.
12FF8011 AMS filament has run out. Please insert a new filament into the AMS and click the retry button.
12008012 Failed to get AMS mapping table. Please click the retry button to continue.
12018012 Failed to get AMS mapping table; please click the retry button to continue.
12028012 Failed to get AMS mapping table; please click the retry button to continue.
12038012 Failed to get AMS mapping table; please click the retry button to continue.
12FF8012 Failed to get AMS mapping table; please click the retry button to continue.
12008013 Timeout while purging old filament. Please check if the filament is stuck or the extruder clogged. After troubleshooting, click the retry button.
12018013 Timeout while purging old filament. Please check if the filament is stuck or the extruder clogged. After troubleshooting, click the retry button.
12028013 Timeout while purging old filament. Please check if the filament is stuck or the extruder clogged. After troubleshooting, click the retry button.
12038013 Timeout while purging old filament. Please check if the filament is stuck or the extruder clogged. After troubleshooting, click the retry button.
12FF8013 Timeout while purging old filament. Please check if the filament is stuck or the extruder clogged. After troubleshooting, click the retry button.
12004001 Filament is still loaded from the AMS when it has been disabled. Please unload AMS filament, load from spool holder, and restart print job.
12014001 Filament is still loaded from the AMS when it has been disabled. Please unload AMS filament, load from spool holder, and restart print job.
12024001 Filament is still loaded from the AMS when it has been disabled. Please unload AMS filament, load from spool holder, and restart print job.
12034001 Filament is still loaded from the AMS when it has been disabled. Please unload AMS filament, load from spool holder, and restart print job.
12FF4001 Filament is still loaded from the AMS when it has been disabled. Please unload AMS filament, load from spool holder, and restart print job.
12008014 Failed to check the initial filament position of all slots; please remove the filament in the tool head. After troubleshooting, click the retry button.
12018014 Failed to check the initial filament position of all slots; please remove the filament in the tool head. After troubleshooting, click the retry button.
12028014 Failed to check the initial filament position of all slots; please remove the filament in the tool head. After troubleshooting, click the retry button.
12038014 Failed to check the initial filament position of all slots; please remove the filament in the tool head. After troubleshooting, click the retry button.
05004016 The MicroSD Card is write-protected. Please replace the MicroSD Card.
05004017 Binding failed. Please retry or restart the printer and retry.
05004018 Binding configuration information parsing failed, please try again.
05004019 The printer has already been bound. Please unbind it and try again.
0500401A Cloud access failed. Possible reasons include network instability caused by interference, inability to access the internet, or router firewall configuration restrictions. You can try moving the printer closer to the router or checking the router configuration and then try again.
0500401B Cloud response is invalid. If you have tried multiple times and are still failing, please contact customer service.
0500401C Cloud access is rejected. If you have tried multiple times and are still failing, please contact customer service.
0500401D Cloud access failed, which may be caused by network instability due to interference. You can try moving the printer closer to the router before you try again.
0500401E Cloud response is invalid. If you have tried multiple times and are still failing, please contact customer service.
0500401F Authorization timed out. Please make sure that your phone or PC has access to the internet, and ensure that the Bambu Studio/Bambu Handy APP is running in the foreground during the binding operation.
05004020 Cloud access rejected. If you have tried multiple times and are still failing, please contact customer service.
05004021 Cloud access failed, which may be caused by network instability due to interference. You can try moving the printer closer to the router before you try again.
05004022 Cloud response is invalid. If you have tried multiple times and are still failing, please contact customer service.
05004023 Cloud access rejected. If you have tried multiple times and are still failing, please contact customer service.
05004024 Cloud access failed. Possible reasons include network instability caused by interference, inability to access the internet, or router firewall configuration restrictions. You can try moving the printer closer to the router or checking the router configuration before you try again.
05004025 Cloud response is invalid. If you have tried multiple times and are still failing, please contact customer service.
05004026 Cloud access rejected. If you have tried multiple times and are still failing, please contact customer service.
05004027 Cloud access failed; this may be caused by network instability due to interference. You can try moving the printer closer to the router before you try again.
05004028 Cloud response is invalid. If you have tried multiple times and are still failing, please contact customer service.
05004029 Cloud access is rejected. If you have tried multiple times and are still failing, please contact customer service.
0500402A Failed to connect to the router, which may be caused by wireless interference or being too far away from the router. Please try again or move the printer closer to the router and try again.
0500402B Router connection failed due to incorrect password. Please check the password and try again.
0500402C Failed to obtain IP address, which may be caused by wireless interference resulting in data transmission failure or DHCP address pool of the router being full. Please move the printer closer to the router and try again. If the issue persists, please check router settings to see whether the IP addresses have been exhausted.
0300010000010001 The heatbed temperature is abnormal; the heater may have a short circuit.
0300010000010002 The heatbed temperature is abnormal; the heater may have an open circuit, or the thermal switch may be open.
0300010000010003 The heatbed temperature is abnormal; the heater is over temperature.
0300020000010001 The nozzle temperature is abnormal; the heater may have a short circuit.
0300020000010002 The nozzle temperature is abnormal; the heater may have an open circuit.
0300020000010003 The nozzle temperature is abnormal; the heater is over temperature.
0300030000010001 The speed of the nozzle fan is too slow or stopped. It may be stuck or the connector is not plugged in properly.
0300030000020002
0300040000020001 The speed of the part cooling fan is too slow or stopped. It may be stuck or the connector is not plugged in properly.
0300050000010001 The motor driver is overheating. Its radiator may be loose, or its cooling fan may be damaged.
0300060000010001 Motor-A has an open-circuit. There may be a loose connection, or the motor may have failed.
0300060000010002 Motor-A has a short-circuit. It may have failed.
0300070000010001 Motor-B has an open-circuit. The connection may be loose, or the motor may have failed.
0300070000010002 Motor-B has a short-circuit. It may have failed.
0300080000010001 Motor-Z has an open-circuit. The connection may be loose, or the motor may have failed.
0300080000010002 Motor-Z has a short-circuit. It may have failed.
0300090000010001 Motor-E has an open-circuit. The connection may be loose, or the motor may have failed.
0300090000010002 Motor-E has a short-circuit. It may have failed.
03000A0000010001 Heatbed force sensor 1 is too sensitive. It may be stuck between the strain arm and heatbed support, or the adjusting screw may be too tight.
03000A0000010002 The signal of heatbed force sensor 1 is weak. The force sensor may be broken or have poor electric connection.
03000A0000010003 The signal of heatbed force sensor 1 is too weak. The electronic connection to the sensor may be broken.
03000A0000010004 An external disturbance was detected on force sensor 1. The heatbed plate may have touched something outside the heatbed.
03000A0000010005 Force sensor 1 detected unexpected continuous force. The heatbed may be stuck, or the analog front end may be broken.
03000B0000010001 Heatbed force sensor 2 is too sensitive. It may be stuck between the strain arm and heatbed support, or the adjusting screw may be too tight.
03000B0000010003 The signal of heatbed force sensor 2 is too weak. The electronic connection to the sensor may be broken.
03000B0000010004 An external disturbance was detected on force sensor 2. The heatbed plate may have touched something outside the heatbed.
03000B0000010005 Force sensor 2 detected unexpected continuous force. The heatbed may be stuck, or the analog front end may be broken.
03000B0000010002 The signal of heatbed force sensor 2 is weak. The force sensor may be broken or have poor electric connection.
03000C0000010001 Heatbed force sensor 3 is too sensitive. It may be stuck between the strain arm and heatbed support, or the adjusting screw may be too tight.
03000C0000010002 The signal of heatbed force sensor 3 is weak. The force sensor may be broken or have poor electric connection.
03000C0000010003 The signal of heatbed force sensor 3 is too weak. The electronic connection to the sensor may be broken.
03000C0000010004 An external disturbance was detected on force sensor 3. The heatbed plate may have touched something outside the heatbed.
03000C0000010005 Force sensor 3 detected unexpected continuous force. The heatbed may be stuck, or the analog front end may be broken.
03000D0000010002 Heatbed homing failed. The environmental vibration is too great.
03000D0000010003 The build plate is not placed properly. Please adjust it.
03000D0000010004 The build plate is not placed properly. Please adjust it.
03000D0000010005 The build plate is not placed properly. Please adjust it.
03000D0000010006 The build plate is not placed properly. Please adjust it.
03000D0000010007 The build plate is not placed properly. Please adjust it.
I may be guessing here but could 03000D0000010008 also be the same error?
Maybe they would be willing to post the ones people have asked about?
Bonjour J ai une erreur inconnue : 03008011 001017
pas dans la liste ci dessus
bcq de rater plaque gold haute temperature mise en chauffe de la plaque a 50°C
merci a tous
cordialement
i got 0300 8013… if i press continue it just goes on… is this a bug or something???
edit:
i found the answer… i saw there was a orange pause mark on the right side inside the slicer…
removed it and the message went away…
i must have accidentialy set a pause on the first layer… problem solved…
Hi,
please, where did you find hms_en.json file? In BambuStudio? I need more recent codes.
Regards Ondrej.
SOLVED - Chat GPT found it.
So are you just bragging or are you going to share the solution?
Of course.
The file hms_en.json you’re looking for is associated with Bambu Lab and their Health Monitoring System (HMS) for 3D printers. This file contains error codes and descriptions for Bambu Lab printers. It appears that the hms_en.json file can be found on your computer if you have Bambu Studio installed. The file path is typically C:\User\USERNAME\AppData\Roaming\BambuStudio\hms .
Thank you for that data. :+1: This is quite helpful.
Here is the short cut using the windows environmental variable.
%appdata%\BambuStudio\hms
The quickest way to access it from the keyboard is to copy the variable above and hold the windows key+R then enter
Windows Start Key LOGO+R
And now, I am bragging. I am working on printing from own farm server.
I am not able to add some picture or link. On Facebook, 3DOrchestrator group.
How can I copy this list of error messages on Bambu X1c?
It is just text. Right-click the hms_en.json file, select Edit with Notepad, or select “Open with” and use the program of your choice.
Honestly I’d rather have a list of the accurate and functional g- & m- codes a Bambu labs printer uses/can use…
Select members of the community have taken upon themselves to discover the codes meanwhile this platform is “closed” source and its meaningless as if they want us to reinvent the wheel all while it would be simple for them to add it to the wiki. .
The recent firmware adapted the error’s description with simple photos and summary so it should be straight forward for people.
