Glad you got workable solutions before I had a chance to see this.
But yes, if you download the preset .zip file you can extract the files and use something like notepad++ to read the contents.
Just for FYI the Panchroma PLA @BBL X1C.json file has (most of which you probably wouldn’t worry about anyway):
“name”: “Panchroma PLA @User”,
“from”: “User”,
“cool_plate_temp”: [
“60”
“eng_plate_temp”: [
“60”
“hot_plate_temp”: [
“60”
“textured_plate_temp”: [
“60”
“cool_plate_temp_initial_layer”: [
“60”
“eng_plate_temp_initial_layer”: [
“60”
“hot_plate_temp_initial_layer”: [
“60”
“textured_plate_temp_initial_layer”: [
“60”
“overhang_fan_threshold”: [
“50%”
“overhang_fan_speed”: [
“100”
“slow_down_for_layer_cooling”: [
“1”
“close_fan_the_first_x_layers”: [
“1”
“filament_end_gcode”: [
“; filament end gcode \n”
“filament_flow_ratio”: [
“0.95”
“reduce_fan_stop_start_freq”: [
“1”
“fan_cooling_layer_time”: [
“100”
“filament_cost”: [
“19.99”
“filament_density”: [
“1.32”
“filament_deretraction_speed”: [
“nil”
“filament_diameter”: [
“1.75”
“filament_is_support”: [
“0”
“filament_max_volumetric_speed”: [
“16”
“filament_minimal_purge_on_wipe_tower”: [
“15”
“filament_retraction_minimum_travel”: [
“nil”
“filament_retract_before_wipe”: [
“nil”
“filament_retract_when_changing_layer”: [
“nil”
“filament_retraction_length”: [
“nil”
“filament_z_hop”: [
“nil”
“filament_z_hop_types”: [
“nil”
“filament_retract_restart_extra”: [
“nil”
“filament_retraction_speed”: [
“nil”
“filament_settings_id”: [
“filament_soluble”: [
“0”
“filament_type”: [
“PLA”
“filament_vendor”: [
“Polymaker”
“filament_wipe”: [
“0”
“filament_wipe_distance”: [
“nil”
“nozzle_temperature_initial_layer”: [
“220”
“full_fan_speed_layer”: [
“0”
“fan_max_speed”: [
“100”
“fan_min_speed”: [
“100”
“required_nozzle_HRC”: [
“3”
“slow_down_min_speed”: [
“10”
“slow_down_layer_time”: [
“4”
“filament_start_gcode”: [
“; filament start gcode\n”
“nozzle_temperature”: [
“220”
“temperature_vitrification”: [
“58”
“nozzle_temperature_range_low”: [
“190”
“nozzle_temperature_range_high”: [
“240”
“additional_cooling_fan_speed”: [
“70”
“compatible_printers”: [
“Bambu Lab X1 Carbon 0.4 nozzle”,
“Bambu Lab X1 Carbon 0.6 nozzle”,
“Bambu Lab X1 Carbon 0.8 nozzle”,
“Bambu Lab P1S 0.4 nozzle”,
“Bambu Lab P1S 0.6 nozzle”,
“Bambu Lab P1S 0.8 nozzle”,
“Bambu Lab X1E 0.4 nozzle”,
“Bambu Lab X1E 0.6 nozzle”,
“Bambu Lab X1E 0.8 nozzle”
“version”: “1.7.0.12”
