Poor Quality Top Layer
Very good experience!
FYI my auto calibration for pa/flow dynamics show also between 15-18 with different filaments. Manual with bambu studio usually around 18-22. From my manual test I can see much higher pressure advance.
Also I got better results by dropping flow rate around 15mm3/s for the matte. And from what I see really different speeds require kind of custom tuning.
I also had in mind to try tuning via Orca but not able to get it working from the first time with the plug in. And liked to buy a flash drive but this got delayed.
But in general your results confirm mine, I was not brave enough to dial more PA. And 0.03 was showing already much better results.
For now only white PLA Basic is close to the original specs and show good results with just a bit more pa around 0.024. All other colors and brands PLA filaments require some more tuning. And I do not have time now to play with different materials.
I am wondering now if this poor behavior is related to bad FW/design. Or just some mechanical components are bad and the extruder really do not have capacity to react as expected, and cover the needed dynamic, which requires “custom” settings for every scenario.
EDIT:
Interesting topic though:
