My PETG print looks great on the bottom & right side but bad on the left and top side. The bottom surface pattern gets squished at the left and top side.
Filament: voxelab White PETG
Plate: Whambam pex
Printing temp: 270
I run the bed leveling & dont remove the plate after bed leveling. This happened on 2 attempted prints today and a few weeks back.
Well the flatter the better also as it warms up it might be changing even more of a gap the Bambu ABL can help with small amounts of changes but when it gets to big it will effect your layers.
First layer test:
Filament: Overture White PLA
Plate: Whambam pex
Printing temp: 220
Plate was cleaned with 99% IPA before printing. The white section at the bottom right is the first layer pealing off the plate but that was after I had taken the plate out.
Did you clean your carbon rods and adjust your x & y belts they will loosen up from when the printer was new I have seen loose belts make ripples on the rear area of the bed after adjusting the belts it stopped on mine if you see the x & y belt tensioners move you know the belts were loose.
Well I don’t know what Bambu lab acceptable heat bed deviation spec is when they will ship a new bed to a customer or wait a little more until they get a better solution let’s hope
I am having similar issues on my engineering plate with regards to Z offset at 90C bed temp , 280 nozzle for PA-CF
Please check out the video i linked. Seems nozzle lays down filament in the air for some reason. This is not happening with cool plate + PLA.
[type or paste code here](https://www.youtube.com/shorts/exBcCUrwtIM)
As for the cool plate, i have the first layer patchy in some areas. I have already done flow cal with orca and run the calibration multiple times.
