Prime Tower for Manual Filament Change
I’ve been trying to print some name tags using two different colors. I’m able to do the “pause, unload, and load” process for pretty good results. However, many times there will be gobs of filament that will ruin the first piece that the nozzle touches upon resuming. I know with the AMS, there’s a prime tower that addresses this issue. Is there a way to add a prime tower to my build plate so that the nozzle will prime itself before resuming the print?
Same issue here/concern Any luck with getting a PT with manual changes?
Could you add a cylinder object with the height the same as the last color change. Then do the pause just before it starts on the cylinder so it will act as a wipe tower?
