First my p1p did really great print at 100% speed.
And since about a week i cant get consistent quality anymore.
At 50% speed the print comes out perfect.
But at 100% it leaves all nasty stuff and looks to be under extruding some of the time.
You might look at SoftFever’s fork of Bambu Studio.
It allows you to run some calibrations not included (yet) in Bambu’s version of Studio.
I was having strange issues with two filaments and when I ran the calibration suite (there’s 3 tests) and plugged the values into the Filament settings in Studio it totally handled the issues.
It’s here, look over the Calibration:
And the Main page is here:
Bambu Lab themselves have included some of his code into Studio, so you know you’re good using it. Search it on this Board and you’ll see.
Is this Bambu Filament? What temps are you using?
I have the same forn1 filament at the moment.
Its onlyndoing this for black pla. But this filamentbprinted file before.
Ivebprinted 3.5kg andbfrom then it started giving artifacts.
Ive cleaned nozzle wich was suprisingly clean.
Im not using bambu pla.
Regarding temperature ive tried various temperatures for the filament, ranging from 195 upto 220.
All resulting exactly the same.
After the first layer the printer speeds up on 100%
That initial layer is perfect.
The artifacts start from the 2nd layer.
Well, if it’s one filament you have your answer, it probably needs a different flow rate, which is calibrated by the SoftFever tests.
Good luck!
BTW - you don’t “install” SoftFever software, just unzip to where you want and make a shortcut to the main exe file. (Windows) You can also right click and create a Desktop shortcut or pin to Start.
Only still weird the first 3.5kg of filament worked flawless, that kinda puzzles me.
Anyhow if softfever might fix the problem its worth investigating.
Thank you very much for your help!
Almost weekend so time to do some calibrations
partially clogged nozzle. until you do a cold pull every other troubleshooting measure is a waste of time. however i have no idea how to do one on a Bambu since they don’t let you release the tension on the extruder gears
Yours pictures really don’t look like it is a calibration problem…
EDIT : except if you use auto-calibration that failed (wich you cannot know as the studio dont give you any information on the auto-calibration result) and get a very high pressure advance
But generally you should have correct result without any calibration, calibration just help to improve print.
Try the cool plate with autocalibration turned on, to be sure.
In the end the calibrations did not give the result.
Still the same things happen on normal speed.
In silent speed the print is perfect.
Aa well ill take it… lol
I can’t tell ya how many times I’ve had to tell people to stop being in such a hurry in 3D printing. An extra 20 mins isn’t worth the failures or the cost.
The Pros on here have already learned that lesson. That’s what makes the Bambu’s so cool - for most prints it’s a game changer on speed, but there will always be models that the answer is … slower.
This stuff gets complex at times! Glad you got it running, and at least you have some new tools in your bag, eh?
Well its not that models. It looks like the black pla filament of 123-3d just cant be printed at high speeds.
In the photo i use their white at high speed without all the jitter and artifacts.
Im only facing this problem with their black filament at the moment.
The first black batch printed fine, its the 2nd and 3rd batch of their black that dont.
So they might have been contaminated filaments.(ive had thos before with filaments from china where the nozzel would get clogged and unclogged by the unpyre filament on my old prusa i3)
(i have about 15 types of filament here printing all fine except for that 1!)
Speedwise i dont care about time.
50% bambu speed is still twice as fast as my old ender3
And yes thank you very much for the softfever studio! Ive tried it on 2 other filaments wich were good printing filaments.
And this improved their overall quality!
A tool im sure ill be using more often!
That’s great! This is the core of the 3D community, helping each other. This is such a complex subject, part engineering, part chemistry, part art, and sometimes part voodoo. LOL
BTW - don’t forget to keep your filaments dry. I can’t tell you how many times I started a print, it went to hell and I started thinking all these complex thought to fix then smacked myself in the head and dried my filament. Bam! fixed. Even PLA .
Cheers!
at best it is ± 10% according to BL the self’s, its a ballpark estimate for a surgeons value.
same for the auto low calibration for the x1c. its not good. try to make ten calibrations in a row with the same profile and see the variations it will give.
if the filament is very matte and not blue or red it give a fairly accurate value.
currently my goto recipe is pla=1/2, petg=1/3,pa=1/5.
fine tune from there has saved me hundreds of hours of calibration.
found the deviation from the auto cali’s to at best what they claim as the worst.
its all bout the benjamin’s, so they lie as all the other companies.
like their pla silk, default value of 21 cubed? when their own stock hotend craps out at around 13?!? its a bit deceptive, but thats the market today…
when in doubt check the manufacturers recommendations, not the forums or other ppl like me😂
we get it right often, but the maker of the filament should know best how their product should be used compared to us hillbillies👍
if you run into issues just divide the flow rate and speeds accordingly first. works in 95% of conditions and filaments.
lastly to the late to the party rant, always keep the plate clean as f…
