Printing with PETG-HF - Issues?
I’ve been printing with Bambu PETG-HF for a few weeks now on my X1C. I’ve tried default settings, slowed down initial layer to 25 , turned up the heat … fiddled around a fair bit.
However, My initial layer always looks the same as this (this is a slice of it):
Screenshot 2025-02-12 at 12.18.13 PM
Any suggestions on how to get this nice and smooth? (or smoother) It is the first thing people see when they look at my product, and it just doesn’t appear polished as a final production version of something.
I have a dehydrator and have dried my PETG to death, so it is not that :wink:
What type of build plate are you using?
Which brand of PETG-HF are you printing with?
There could be several factors causing this issue. Here are a few possibilities to consider:
Nozzle positioned too close to the build plate (Z-offset too low)
Over-extrusion on the first layer
First layer temperature set too high
First layer printing speed too fast
Uneven or dirty build plate surface
Inconsistent bed leveling or a warped build plate
Excessive or insufficient cooling on the first layer
Incorrect flow rate calibration for PETG-HF
Using a textured build plate instead of a smooth one
Incorrect filament diameter settings in the slicer
Inadequate nozzle pressure relief between extrusions
Inconsistent extrusion due to partial nozzle clogging
Improper adhesion settings (e.g., glue or adhesion sheets affecting flow)
Incorrect acceleration settings causing filament shifts
I’ve printed around 20–30 kg of Bambu Lab PETG-HF so far, but I use a WhamBam Carbon Fiber Plate, which requires higher temperatures for both the bed and the nozzle. However, I stick to the stock speed settings. I experienced first layer issues when my build plate was too cold. If you’re using a WhamBam plate, you can check the temperature settings I use here:
I’m using Bambu PETG-HF along with a Bambu Cool Plate Supertack
That’s the only plate I haven’t tried, so I’m not sure how much I can help with this specific issue.
Have you tried increasing your bed temperature by 5°C to see if it improves the first layer quality?
When I was dialing in the correct temperatures for my carbon fiber plate, I printed a single 200x200 mm layer to determine when I achieved a solid, even first layer.
Good advice, I’ll give it a go.
How’s that working out for you?
