Remove LAN mode limitations
The following functions do not work in LAN-only mode.
  • SD card access
  • Handy app
  • Firmware updates
The first two shouldn’t require internet access at all. Firmware updates obviously have to be downloaded from the internet. The current method of updating is:
  1. Disable LAN mode
  2. Log back in using Bambu handy
  3. Download and install update
  4. Re-enable LAN mode
  5. Reconnect printer to slicer, as the access code has changed (maybe it should be stored on the SD card to survive updates)
Possible ways to solve this are:
  • Allow users to manually install updates from the SD card.
  • Allow printers in LAN-only mode to connect to the internet to download updates.
I think what most people want from LAN-only mode is simply to not send files to Bambu and back when the printer is only a few feet away, rather than not connecting to the internet at all. It wouldn’t be unreasonable to access the internet for updates.
Ideally, LAN mode shouldn’t be needed at all. Bambu Studio/Handy should attempt to connect directly to the printer by default, and only use Bambu servers if it’s unable to, e.g., when not on the same LAN. This would retain the advantages of LAN mode while still being able to remotely monitor prints.
I’d like to see this also.
I just disagree with you in this point:
If I don’t want it to use the cloud, I don’t want it to use the cloud :grinning: no matter what happens. If I want to start printing outside my network, I than need to create a VPN.
I think the intent was to say Ideally, CLOUD mode shouldn’t be needed at all.
You can access the SD card over LAN in LAN-only mode using FTP to the printer, so your first bullet point isn’t correct.
FTP access to the MicroSD is available (at least on the X1C) in cloud or LAN-only mode.
But in LAN-only mode, you cannot access the MicroSD card from Studio, which is an unnecessary restriction.
Yes, I agree. It should of course have been accessible from Studio as well, but since you can access it over LAN (in any mode) it isn’t completely inacessible, as one might think after reading the OP.
That’s the idea, yeah. It should always connect locally if possible. A separate setting shouldn’t be necessary.
I too want full access to my printer when in lan mode. I hate using the cloud for security reasons. It also slows things down even further. When I am sending a 70M print file, I dont want to send it to the cloud, and then back down, and then through my wifi, again.
And I want access to the SD card stuff as well.
I do all my work from my pc, so being forced to “use the App” is a pain.
What part of your printer do you have limited access in LAN mode? Do realize this thread is 6 months old and LAN mode has significantly more features.
As far as I’m aware, nothing has changed. All of the above still applies.
The firmware should be updated with lan use over local for example home wifi and add multiple users.
Be patient. It will.
Update from SD card is in beta right now.
Multiple users… ¯\_(ツ)_/¯
Another slightly frustrated user here.
I recently aquired the A1 with AMS and I absolutely love the printer!
But I do not want to use a cloud service, especially for things, that are absolutely unnecessary to use external servers.
I do not necessarily need App-Access, but I want all the features to be available in Bambu Studio in LAN-mode.
I also have a problem where I constantly have to re-connect Bambu Studio to the printer by entering the code from the LAN-only page again and again.
Don’t get me wrong. I love the printer and the UX is really great for almost everything. And I suppose there are many users which don’t have a problem using the cloud. I just would love to be able to fully use my fabulous printer without using a cloud service.
You can’t read the SD card data in LAN mode from Bambu Studio. There’s zero reason for this to be honest. If you can access it via cloud in Bambu Studio, then you should be able to access it in LAN mode. There’s no logical reason for this functionality to be gated behind a cloud service.
As a LAN mode user I agree to these limitations being removed so we can have all the same access as the cloud mode. :+1:
You can access the SD card via FTP.
There are workarounds, sure… but this is a unnecessary step that requires extra software and knowledge for most users, when it could be handled within Bambu Studio.
Oh, and i just found out: cancelling a failed object (“Skip Objects” in Bambu Lab Speak) is also only possible through the App (and therefore with cloud connection) on the A1 and P1 series. This sucks big time!
Please, Bambu Labs, where is the reason? Please add this to Bambu Studio.
I did not understand why you would need those programs. They only allow file transfer, no other control on printer. When the print finishes turn of the printer take the SD card and put it to card reader transfer files. Put back the SD car and turn on printer.
