Remove loud vibration by Start printing
Hi,
i have a little Question. My Printers are in a Flat. Often the Prints are finished between 22 and 23 o Clock. To start a new Print the Printer make loud vibratings (while homing etc.). Can i disable it for nightprints? I wont annoy my neighbors.
Thanks
You can turn off automated calibration; if it is not working (it worked in the past), you can edit the machine start g-code.
The g-code to comment is in the “mech mode fast check”. If you change the g-code, I advise you to stand near the printer for the first time to check that everything goes as planned.
These are the louder vibrations. You may need to dump the printer vibration if it is a general issue. I use a typical solution consisting of a heavy slab topped with foam, which works quite well.
yes its not a problem to stand by the printer while it starts.
so this is the only one i need to change?
;===== mech mode fast check============================
;G1 X128 Y128 Z10 F20000
;M400 P200
;M970.3 Q1 A7 B30 C80  H15 K0
;M974 Q1 S2 P0
;M400 P200
;M970.3 Q0 A7 B30 C90 Q0 H15 K0
;M974 Q0 S2 P0
;M975 S1
;G1 F30000
;G1 X230 Y15
;G28 X ; re-home XY
I cannot access the slicer to confirm if this is the only required change. It used to be.
Some interesting posts:
Note:
From my understanding, this code section compares to the printer calibration values, verifying if the calibration is still valid.
If the printer sits in a stable position, it may be redundant.
Nevertheless, I never did it and cannot be precise about possible issues.
It works with my changes. I added it to a “no vibration” Profile. Thanks
I want to change the printer profile only in cases where I have printed before and the mech mode was active during the last print. My printer is positioned on a large stone and doesn’t move much. I don’t think it would be a problem to disable it for some prints at night.
I also have my p1s on a concrete block on these Machine Matt. i would love to disable it when i do multiple sequencial Prints. it is very loud.
Will this also work for the A1 Mini? My Gcode look different:
M1002 gcode_claim_action : 3
G0 X25 Y175 F20000 ; find a soft place to home
;M104 S0
G28 Z P0 T300; home z with low precision,permit 300deg temperature
G29.2 S0 ; turn off ABL
M104 S170
; build plate detect
M1002 judge_flag build_plate_detect_flag
M622 S1
G39.4
M400
M623
G1 Z5 F3000
G1 X90 Y-1 F30000
M400 P200
M970.3 Q1 A7 K0 O2
M974 Q1 S2 P0
G1 X90 Y0 Z5 F30000
M400 P200
M970 Q0 A10 B50 C90 H15 K0 M20 O3
M974 Q0 S2 P0
M975 S1
G1 F30000
G1 X-1 Y10
G28 X ; re-home XY
Hi!
I’ve recorded a video how to solve this problem.
Thanks!
You need to comment out this text for A1 Mini. Comment with semicolon symbol before start of the each line.
G1 Z5 F3000
;;Vibration calibration start
;G1 X90 Y-1 F30000
;M400 P200
;M970.3 Q1 A7 K0 O2
;M974 Q1 S2 P0
;G1 X90 Y0 Z5 F30000
;M400 P200
;M970 Q0 A10 B50 C90 H15 K0 M20 O3
;M974 Q0 S2 P0
;M975 S1
;G1 F30000
;;Vibration calibration end
G1 X-1 Y10
G28 X ; re-home XY
I have comented out this entire “mech mode fast check” section and I still get a single vibration burst. Is there a way to get rid of it as well?!
