Resonance calibration noise before each print
New to 3D print and got my P1S last weekend.
Everything goes well but there are two pulses of loud motor noise before each print which sounds like the loudest noise I can hear in a full calibration process.
It seems that M970.3/M974 in machine start g-code causes the noise:
;===== mech mode fast check============================
;G1 X128 Y128 Z10 F20000
;M400 P200
;M970.3 Q1 A7 B30 C80  H15 K0
;M974 Q1 S2 P0
;M400 P200
;M970.3 Q0 A7 B30 C90 Q0 H15 K0
;M974 Q0 S2 P0
M975 S1
G1 F30000
G1 X230 Y15
G28 X ; re-home XY
;===== fmech mode fast check============================
Is it normal to hear such a loud noise for this “fast” check? Is it necessary to run the fast check for every new print?
Relevant topics:
It’s normal. The printer does a resonance sweep at the start of every print. Two different frequency bands, a second or two each time. If it detects that the resonant properties of the mechanics have changed, it will post a warning that you need to tighten belts and clean rods.
Yeah. It’s loud. :slight_smile:
If you get yourself a heavy stone/concrete tile and you put the printer on that, the additional mass will reduce how much the printer’s resonance sweep excites the surface it’s sitting on. That excitation causes some amplification of the noise. The added mass might also improve high speed printing performance depending on how “wobbly” the table/bench is.
Hi, I have another issue. My noise more different yours. How can I solve this problem? https://www.youtube.com/shorts/12LwkYQUujI
That is normal. It’s not a problem.
The p2s has something else, but my neighbors would really appreciate me turning this off like I did on my a1 mini.
is this correct for the p2s?
;===== mech mode sweep start =====
M1002 gcode_claim_action : 3
G90
G1 X128 Y128 F20000
G1 Z5 F1200
M400 P200
M970.3 Q1 A5 K0 O1
M970.2 Q1 K1 W74 Z0.01
M974 Q1 S2 P0
M970.3 Q0 A7 K0 O1
M970.2 Q0 K1 W74 Z0.01
M974 Q0 S2 P0
M975 S1
M400
;===== mech mode sweep end =====
Do I just delete that to get rid of this?
Delete it, or just put a semi-colon at the beginning of each line in case you want to restore it later.
Then save it as a user preset.
Awesome, thats how I have my a1 mini set, since its called something else instead of mechmode fast check I wanted to be sure it was the same thing. THANKS
;M1002 gcode_claim_action : 3
;G90
;G1 X128 Y128 F20000
;G1 Z5 F1200
;M400 P200
;M970.3 Q1 A5 K0 O1
;M970.2 Q1 K1 W74 Z0.01
;M974 Q1 S2 P0
;M970.3 Q0 A7 K0 O1
;M970.2 Q0 K1 W74 Z0.01
;M974 Q0 S2 P0
;M975 S1
;M400
like that?
