Removing the tube
This is an absolute beginner question, but how exactly do I remove the filament tube that’s attached to the extruder?
I want to try a cold pull since my nozzle seems to be clogged and won’t print, but all the videos I was able to find were from different series than the P1P and don’t seem to work for it.
I’ve seen people push a part down to pull it out, but no matter what I push, nothing gets ‘pushed down’, maybe I’m pushing the wrong parts??
I’d really love for someone to be able to help me, preference to photos or something so I can see exactly what to do if possible !
https://wiki.bambulab.com/en/x1/troubleshooting/broken-filament-anywhere
https://wiki.bambulab.com/en/p1/maintenance/ptfe-tube
To remove the PTFE tube, carefully press and hold down on the black ring, then remove the PTFE tube by gently pulling it out. (It often helps to push in with the ptfe tube when you push down on the black ring.)
It’s really a pain by hand.
I really like this tool that makes it a lot easier.
So if the filament is till engaged, is it possible to remove tube? Or do you have cut filament?
Well yeah but if my printer is clogged, I can’t print out another tool, now can I?
I’m pressing down but it’s not budging
If it’s clogged how it usually clogs no tool will help you anyway.
If I can’t release the PTFE tube here then there is usually a clog in the extruder gear. You need to remove the 3or4 screws which hold the extruder gear assembly in while keeping the tube attached. This will allow you to move it out of the hotend and let you rotate it to access the back.
Remove the screws on the back of the assembly to expose the gear where your clog most likely is. Snip that clog and clear the path and you can then release the tube and rebuild.
Or clearer than my word salad: Extruder clog | Bambu Lab Wiki
Never mind. I just needed to remove the AMS upward to release some tension
I can’t figure out how to release the PTFE tube either. What does it mean to “remove the AMS upward”.
Note, I have a P1S with AMS.
Thanks :+1: just going to print to avoid messing. My BASF tpu does not fit in the ams 2 pro as well
I’m curious if you ever found out the answer to this question. I am having the same problem
Thank you on this MUCH MORE effective explanation to initially push down on the tube. This helped in next pulling the tube. This of course while pushing down on the retaining ring. I found this maybe a requirement to replace this tube as the tubing appears to show a lot of wear from the retaining ring.
The tube will show marks from where the retaining ring grabs it. This is normal. If you are concerned about the tube coming out then you can trim a couple mm’s off the end of the tube so that the retaining ring seats into an unmarked section of the tube. Do note that you can only do this a couple times before the shortened length of tube could cause incorrect homing issues.
