Hi
I have had issues with spools being pulled out of slots since I received my printer some time ago.
Now I have identified the issue.
After retracting (unloading) the fillament, the roller gets stuck and can not spin in the load direction at all. I can not even spin it by hand. This remains until I manualy spin the roller in the unload direction for just a bit. Then some gears release and it can then spin freely in both directions.
Does anyone know this issue? Should I contact Bambu support?
I am having this same issue and figured out the gears were not disengaging causing the filament not to feed when switching colors. has anyone gotten a solution yet?
I have this issue also. Re-adding the filament in the AMS, then starting a print, the spool jumps up because the rollers are engaged. The filament is stripped because it is being pulled, but the rollers are holding it back. It may be that i first need to āloadā filamentā rather than just shoving it down the AMS hole. But you woulr think that because it sucks it down, it should know to release the rollers first ? Feels like a bug. Doesnt alwasy happenā¦
I donāt know if this will help any, but Iāve found that the rollers will roll fine until I push the first stage feeder back to load the filament. Then the rollers lock. To unlock the rollers, I just roll the spool backward a little.
Now I routinely load filament by placing the spool on the rollers, roll it back a bit, grab the filament end, roll the spool forward to generate some slack, and finally push the feed horn back to insert the filament. Then I usually roll the spool back a bit to remove the slack. No issues since I changed how I load the filament.
You are spot on tsmith35. I tried this today, and yes, the rollers locked as soon as i fed in the filament. rolling it back a little by hand released the lock. Thanks for your tip.
Bambu labs - if you are listening, can we get a fix for this. Otherwise the filament rolls thrash themselves in the AMS, and it has lead to the filament being flattened or snapped off as the machine tries to load filament, with the ābrakes onā. I also worry about the AMS being damaged whilst theis is happening. Hopefully itās an easy software fix to jog the rollers.
Hi, this comes a year and a half later but I can not thank you enough dude, I felt hopeless on this issue I had with slot number 3 not retracting the filament because the roller did not spin the spool. Therefore the gear spun and I could hear the whining but the only time the spool started spinning was when I pushed the button on the gear assembly.
But now it works flawlessly, thank you very much and have a good day.
everybody has this issue. But it looks like Bamboo does nothing. The things are getting worse when the spool is getting close to the end. Itās almost NOT POSSIBLE to print when you have a base color with supports. The spool stuck almost every second layer. Why BAMBOO does nothing!!! Itās easy to fix with a firmware. Just add tine movement backward to release a lock on ratchet mechanism.
Same problem here. Itās doing my head in, canāt start a print without physically moving the spool to unlock front roller. This defeats the purpose of having the AMS. I start a print then run to the AMS to make sure it feeds properlyā¦atleast Iām getting some excercise, I guessā¦
