For instance:
Search for “Whistle” under “New Uploads” and you’ll find a lot of items of which only very few are actually whistles.
This is caused by fuzzy term matching. It can help correct input errors (such as “chirstmas”, “holloween”), but it can also introduce some unintended additional models.
We are optimizing this case. If everything goes well, the issue will be solved in the next update.
Yeah, pretty fuzzy … ![]()
Unfortunately, in many cases it makes the search pretty useless.
Could you perhaps implement a quick workaround, e.g. turn off fuzzy mode if the search term is enclosed in quotation marks?
By the way – when you search for “Whistle” under “New Uploads” there are 4 whistles in the first 50 entries. This means that more than 90% of the results do not match.
I’ve checked some of the unmatching entries and suspect that “white” in the keywords triggers the selection. “Whistle” to “white” is a pretty big fuzzy range.
Agreed. I rather do two or three searches with smaller result sets to pinpoint what I need rather than wading through a large set of irrelevant results. If anything, you could return exact matches first and then have another section below that says something like, “These results may also be of interest to you…”, where the fuzzy results are returned.
Oh totally, also tags are way too fuzzy. I accidently printed wrong poop catcher. In fact I dont think there was a single one for A1 on the first page of search results (with A1 as tag).
We will have a quick fix for this fuzzy mode next week.
Great, thanks!
If you are still searching, you could try my Poop Deflector …
So 3 more weeks with an almost useless search function?
If new members can’t find the design they want among hundreds of mismatched listings, they may permanently switch to another platform…
In the short term, isn’t it possible to simply deactivate the fuzzy option until the final change is released?
Okay. We may disable the fuzzy option first.
The fuzzy search is disabled for now.
Thank you so much. The hero as usual.
so fuzzysearch is definitely back and i am BEGGING for a way to turn it off, i’m trying to search from a character from a very specific video game and unfortunately since his name is oscar, if i google the name of the video game and oscar it will ONLY give me a sea of oscar awards and not ANY character named oscar anywhere. please please please let me deactivate fuzzysearch it makes it impossible to use the platform, i can’t find a single homestuck thing because it’s just a sea of homer simpson
I’m not sure which video game you’re referring to, but when I add the name of the video game behind it, it shows me the charakter “Oscar” from that video game, not the awards.
Of course, it’s possible that the exact model you’re looking for isn’t on makerWorld, or that the creator forgot to tag it.
Examples that work: “oscar fortnite”
As I said, since you didn’t mention which game you’re talking about, it could, of course, be so obscure that there isn’t a model for it. If you don’t want the award, you can use the most common tags as negative tags:
- trophee
- trophies
- statuette
- oscar award
- trophies
I’m not familiar with that term. Could you please briefly explain what you mean by it? Thanks. Do you mean by that MakerWorld suggests the one closest to you? You can partially avoid this by not using the search field, where MakerWorld suggests the closest match.
So, not the “For You” search. “For You” means the AI is trying to suggest something to you.
Again, what’s a “Homestuck”? Do you mean the character? That’s such a niche thing - MakerWorld probably won’t know about it. MakerWorld is familiar with mainstream characters, but it’s not a database for extremely obscure or rare characters.
You’re actually more likely to find it on Cults3D, if it’s there at all. Give it a try.
Homestuck is a webcomic that was EXTREMELY popular in 2012, and I have seen models for it on makerworld after much scrolling of the search, there are at least 6 prints that I found that are actually related to the webcomic. I KNOW there are models for Oscar from Syberia because a model for Oscar’s Heart shows up in the search bar as a suggestion every time, but when i press enter those results are nowhere to be found.
“Fuzzy Search” is a term for when a search is coded for potential misspellings of a word, such as ‘chrsimas’ or ‘halowee’, it automatically includes many similar words. Currently MakerWorld doesnt have an Exact Search feature, and its Fuzzy Search coding is so intense that it will not allow me to find anything for the very specific and supposedly “niche” content i am looking for. In most situations one would expect a search of “Mezuza” to turn up actual Jewish faith items, but MakerWorld immediately returns searches for ALL religious memorabilia regardless of faith, which given the sheer quantity of christianity memorabilia, usually turns up a sea of jesuses.
I have personalized search turned off in my settings, i have so many tags blocked already, but nothing actually helps the situation.
Alright, let’s walk through this. Pay attention to the search prompt I’m entering:
- tag: Homestuck
Only seven models are showing up. So MakerWorld doesn’t recognize them because the designers simply forgot to tag them - except for those seven.
This isn’t an issue with the search function - it’s most likely a mistake made by the creators when uploading their designs. As far as MakerWorld is concerned, “Homestuck” doesn’t exist there.
You’d have to rely on the designers to tag their models correctly.
Here’s the same thing, but since “Oscar” is often used to refer to awards, let’s flip it around a bit:
- tag: Syberia
Not a single result; nothing was tagged as “Syberia.” This isn’t a search function problem, but a problem with missing tags:
I understand that it seems to you like a search problem - sure, of course - but in reality, it’s a tagging problem. Even MakerWorld can’t do anything about it if the designers forget.
Let’s look at a counterexample: I’m going to pick just a randome anime character… Kakashi Hatake. The designers tagged correctly.
- tag: kakashi hatake
The search function can only be as good as people are willing to provide accurate descriptions and tag their 3D models. Unfortunately, MakerWorld has no control over this.
Disclaimer: Of course, in the context, that such models of “Oscar” or “Homestuck” exist at all on MakerWorld. There’s still the possibility that nobody is uploading those kinds of models.
…and as a bonus to my previous comment, I’ll mention it again - this isn’t an ad for the site - but it’s known for having a lot of unique characters: Cults3D
Is this the “Homestuck” you’re looking for?
Is that the Oscar from Syberia you’re looking for? By the way, this character is so unknown that even cults only lists a few results. I seriously doubt that this character was ever uploaded to MakerWorld in any form or shape at all.
https://cults3d.com/en/3d-model/art/syberia-oscar-custom-design
That also matches my search; take a look here to see which prompt I’m using: There just aren’t any more 3D models of that character, just one for 3D printing.
- Oscar Syberia 3d stl
Since you are intent on talking to me as if I am completely incapable of understanding sense, I am going to use photos to explain to you the exact issue I am having, since you seem to have some magical completely different search function on your account that I do not have. These items are actually tagged as Syberia and have Oscar in the title, the search for me is physically excluding them, and I would very much prefer if you please stop talking down to me.
here you can see the physical tags and the title. Now, let me attempt to actually find this model with the search function instead of having to use Google to do so. How about we try by the listing’s title?
Hmm, that didn’t work. Perhaps searching for Syberia itself will yield different results?
999+ results and none of them are Syberia like the search? That can’t be right, let’s try homestuck search. Since that is a very exact word that is physically tagged and has 6 models, surely those will show up, yes?
Now, when you post photos of YOUR search, they clearly do not have this issue. Is there any reason your search doesn’t have this feature that is hard coded into my search function?
I find it very uncomfortable and disrespectful that you are actively telling me these models on makerworld do not and never have existed, despite showing physical photos of you finding the models on your search. Could you please be more respectful and like… not gaslight strangers online? What are your profile/search settings, how do you have a different version?
