When you make a sword or something else with a vertical tip, the X1C is so lightning fast that it does the last 10 layers or so in a matter of seconds. This means that each layer piling up hasn’t cooled and is still a little weak. The end result is that tips (Or really any thin vertical object at the end of a print) always come out a little crooked as the extruder force pushes it a little back and forth. I noticed we now have a way to change layer height as we approach cone shaped peaks. Do we have a setting to slow down print speed the same way.
The setting is known as “Minimum layer time”.
Most Excellent thank you!!
