[SOLVED] Bad quality when printing PETG
Try my settings which i shared in this test design or the second one from the designer
The first one was the problematic as you will see
Assuming that the filament has been dried and flow and PA(K) factor may be different and needs filament specific calibration. my ones are eSUN
all the rest should be filament agnostic , may be print temp as i tent to print higher normally 240C for eSUN i print 255C or 260C
PETG blob is commonly overexerting or the PA(K) too low
For PETG the flow i run around 1%-2% lower than the measured my one shows 0.99-1.0 and i run it around 0.97-0.98
for PA(K) my factor usually run it bit lower which gives me nicer corners , or at the measured value - my measured value is around 0.05 and run it usually 0.045 to 0.04 even some times lower but then bulging and defects may be seen or the corners a something else which i like in the print
