I’m attempting to add text as a negative part so I need to use a stencil font. I’ve loaded two stencil fonts and they show up in Bambu Studio but when I add text using those fonts they do not render as the stencil font. They appear as simple sans serif letters like Helventica. Is there some restriction on what fonts can be used by Bambu Studio? Apparently all system fonts cannot be used if you want them to render properly.
Ah. Sorry, I did misunderstood your question.
Unfortunately, that is not my forte. Since you probably searched the forum yourself, I fear that this Windows fonts in text-shape - #8 by Scott_M is also not helpful. I am afraid that I am unable to help properly. Apologies and ![]()
Detect thin walls maybe? You might need a .2 nozzle as well depending on the size of the print.
im having this problem too they wont render but it shows up in the drop down menu any solutions???
i want to use stencil font
Did you solve the issue someway?
I just noticed that orcaslicer (2.2.0) works fine with font rendering and slicing on macOS, BS 1.9.x does not.
I had the same problem using the Millie Round Bold font – I used Prusa Slicer to add the text, saved the project and then opened it in Bambu Studio – the text appeared as intended.
Also, you can just use Orca Slicer in Windows – just remember you have to install the font in Windows before it will appear in the slicers. There are plenty of instructions online guiding you through the process. You will need to restart your slicer if it was open during the font installation process.
I just ran into this issue today as well. I think it may have to due with OTF vs. TTF fonts as some of my fonts work and some don’t (most recent I tried that isn’t working is OTF–Fusion 360 also struggles with OTF). They all show up in Bambu, but some display as a simple serif font like you stated. Maybe I’ll try Orca/Prusa since people seem to have had luck with that, but if they work there I don’t see why they wouldn’t in bambu.
On Mac, you have to just copy the fonts in HD (whatever your root hard drive is named) then /Library/Fonts. Then restart Bambu Studio and the fonts will render correctly.
I imagine a similar solution for Windows machines. Hope this helps.
Sadly it doesn’t work with HoboStd.otf
The dropdown menu looks OK, but the placed text is just a standard sans serif font.
Are you on Windows or Mac?
OSX 15.2
I add text to A LOT of things I do. Bambu Studio’s font support is abysmal compared to Orca Slicer. If Orca is an option, use it. I MUCH prefer its handling of text over Bambu Studio.
