Stringing black in white parts
I am struggling with this error on my P1S. The only way to make sure there is no stringing on your printed object is to manually remove the strings while the nozzle is changing color. After several attempts, it was the only time I was able to print a lamp without stringing.
And now I’m starting to suspect the slot where I have that filament set, since I changed the color to another one and it has started stringing, when it didn’t string before. Maybe the PTFE tubes are affecting the filament flow?
Sorry, english is not my best skill :slight_smile:
are there any users with other printers with this issue? Or only the p1s users???
I also noticed that the lightbox maker creates a new profile named P1P with a bed temperature of 65°C instead of 55°C and also increases the flow ratio. Probably there are more settings changed.
My routine now is cleaning the plate carefully, cleaning the nozzle and select the default profile. The results seems better but not perfect yet
I have the same issue on my lightboxes, and I can tell you there are a few things I can confirm aren’t the problem since I have an H2C, it’s not the wiper and it’s not cross contamination. I have tried a long list of settings and go from a little better to a lot worse, but I always end up with a least one small defect in the white. My build plate is very clean and don’t even go there with the wet filament, I have an industrial blast oven and dried my filament for 10 hours at 55°. I only experience this when printing lightboxes. Maybe they are always present in prints you just don’t notice them because you aren’t shinning a light through them. Any suggestions would be appreciated. A coincidence, although it is no way related is I was also working on a Harley-Davidson lightbox.
any update on a solutuion, im sometimes having the same issue, I did find that it could be oxidisation from inside ther nosel making its way out, cold pulling could help. what do you think?
Thanks, I also needed to know this.
That’s normal. It’s just your print leaking oil :upside_down_face:
Hope you get it solved.
When this happened to me it turned out the inside of the silicone sock was disintegrating and tiny black specks were falling into my prints.
@Warmup I feel your pain, I have been fighting with these brack string contamination, that’s not exclusivity of Lego lightboxes :frowning:
the solution I found here was set the filament order with Black at the end for all layers and add pause’s to all coloured layers. each pause I go there inspect manually removing it.
If you wipe down the inside of your printer walls, horizontal surfaces, etc, with a clean, low-lint rag or moistened paper towel, it might surprise you. It did me.
Dust inside a cabinet can get stirred up by air currents during a print and find its way into prints too.
It’s not the only source of stray bits but it is a source.
During critical multicolor prints I watch during color changes and use canned air, masking tape adhesive, or even an x-acto knife if something needs scraping or cutting (carefully so not cutting into build plate).
Still sometimes have failures for stray bits, though.
