Hi, i have problém with stripes on thé walls. Its PLA. I tried different speed and temperature settings.
Please, Does anyone know what could be causing this? Thank
Not very good photo, but here is a list to check ordered by priority
- Check that outer wall is printed at the same speed( on the sliced model select speed to see ) - may have to reduce the outer wall speed
- Dry filament
- flow and K factor calibrations - calibrate for the filament
- reduce outer wall speeds
- Aux fan - off
- some drafts in the environment
Hello - did you ever solve this issue? I have the same problem:
