Sunlu FilaDC i10 dryer cabinet, and other dry filament topics
I will continue to do the coding myself on my projects, though. I don’t learn anything if someone or something else writes my code. I’m also trying to not expand my AI footprint. It imposes huge burdens on people where the data centers are located and represents crippling hits on power and water infrastructure.
And as an aside, if anyone wants a pretty wild blast from the past where science fiction really has become reality with the extremely powerful LLMs, give “Colossus: The Forbin Project” a watch. The tech is museum quality but some of the plot points are spookily accurate now - recursive self improvement, solving long-standing math superstar achievements, probing/hacking other computer systems, developing their own code/language, threatening and gathering information on researchers, etc. It’s big hit after hit, jaw drop after jaw drop.
Hopefully the next book/movie to come so true isn’t “Terminator”. :grin:
Vibe coding specifically refers to people who can’t code, using AI to do all the work.
Your trained/experienced developers are using AI assistance.
I vibe code and I have 35+ years of professional coding experience. My home projects I vibe code because I’m too tired at the end of the day after working with C++, JAVA, Python for 8-10hr. It allows me to get my ideas out-the-door before I run out of interest and abandon the project.
That sounds like ai-assisted coding, not vibe coding.
Getting off-topic so I’ll end here. If I describe the problem to a LLM and then have it write code. It’s vibe coding. AI assisted is what I do at work. I write the code and have LLM review it and offer suggestions.
They call it vibe coding. So I call it vibe coding. ¯\_(ツ)_/¯
I was looking at humidity sensor breakouts on Adafruit and found the HDC3022. It’s sold out there and on DigiKey but looks like a shipment is actually past due at DigiKey.
At $8.95 each I figure might as well just use those since I needed an extra sensor anyway since getting two cabinets. The specs are pretty amazing and even if I don’t need the accuracy and precision now, you never know about the future. Thanks for the heads-up. Adafruit has a whole range of humidity sensors too.
Was playing with the MagTags this morning and it has 4 neopixels to light up the display and a small, kind of terrible speaker on it. Can color code the humidity display to green, yellow, and red based on humidity, flash the LEDs for attention, and even sound an annoying alert if humidity crosses an especially high threshold.
Added - Mouser also carries the HDC3022 breakout from Adafruit but they have an anticipated restock in late January. On the Adafruit waitlist so will see. If they haven’t restocked in the next month will need to choose a different sensor.
But you’re able to specify the program in a much better way, making it more assistance, rather than feeling as you go along.
for example
(1) “make an app to find the duplicate files in this folder … oh it didn’t work, those 2 images look the same but you said they weren’t … now change it again to remove all the weird . files.” 300 iterations later, it somehow works.
vs
(2) write a python program to find duplicate files in a folder; it should take command line input.
ignore files that are known to be metadata, including all the apple ._ files. use md5 checksum to test the files for identity. additionally if the file is an image, also run it though the (whatever) image comparator to check for visual similarity. the output is the a list of the files to be erased to remove duplicates while preserving one copy.
(or however your particular LLM works)
version 2 is “i know i am doing, just do the tedious boring stuff for me” and version 1 is i dunno, just fling stuff at the machine until the code works.
Agreed! Also known as spec-driven AI development. You start with a rough spec, use the AI to help you refine it and identify holes, and eventually you tell it to start coding.
This is a pretty good project if someone wants a framework for doing it:
There are lighter-weight versions out there too, of course. So many tools, so little time to evaluate them…
Something I just noticed today atter reading your note about the lack of availability is that although both the HDC3022 and the SHT45 chips are themselves rated up to 125C, it looks as though most (maybe all?) of the typical breakout boards aren’t. Well, at least some of the components aren’t. For instance, on the adafruit the plastic JST-SH connectors and the green LED likely aren’t rated above 85C. Not a huge deal, because you can just remove them. Not sure about the 10uF ceramic capacitor. If it’s an X5R, it might be rated only to 85C also. I guess either contact adafruit or see if anyone has reported on it, or maybe just replace it with an an X8R (rated to 150C), or maybe you already have an X7R on hand (rated to 125C).
None of that is a worry in the FilaDCi10 though. That’s the beauty of a room temperature cabinet.
What I’m running into is getting CircuitPython loaded on. The MagTags didn’t come with a bootloader and MacOS won’t mount the CircuitPython drive like it does in a heartbeat with the RPi-based feathers.
Hopefully my Linux box can mount it and let me get the bootloader installed. Kind of frustrating they aren’t straightforward to get code onto them. If not Linux, maybe Windows?
Also looking at displays that will work with Feathers.
Update - the MagTag is almost bare metal when you get it with a simple demo loaded. No bootloader and it’s not easy or straightforward to get CircuitPython loaded. There is a way that’s not too bad but probably not easy for those not familiar. And it doesn’t work on Macs. I was only able to load a bootloader and CircuitPython using a Windows box. So rethinking the MagTag. It has some hardware built in that would be handy in this application, but thinking the Feather route is probably the easier way to go if this turns into something others might want. It cuts out features though and would just be basics with no alarms or web pages.
Yeah, it might possibly be moot for another reason:
i.e. the air is likely so dry that measuring it accurately will be difficult. I thought it might be interesting to try to measure RH levels in a filament (or desiccant) dryer’s chamber while drying to see if it might provide a practical signal when to terminate the drying. After all, my clothes dryer works that way. I guess I’ll try it with PLA and PETG first just to see if it might work, as the HDC3022’s preferred temperature range is -20c to 80C, so well within that envelope. At the really high temperatures…well, I only need to cross that bridge if it first proves useful at lower temperatures.. As much as I’d prefer a single chip that’s “good for anything”, It would warrant searching whether at those higher temperatures there might exist chips that could match or beat the HDC3022 in either accuracy or repeatability. Even if the HDC3022 chip and board survived a brief exposure at those higher temperatures, it’s RH sensing afterward may be compromised.
According to the datasheet, the only part strictly needed on an HDC3022 breakout board is a bypass capacitor located in close proximity to the VDD pad. That said, considering that the price of even just the chip itself is more than $5 if you wanted to roll your own, the $8.50 adafruit breakout board is a sweet deal. Even the clone adafruit HDC3022 boards on aliexpress are more than $20.
JLCPCB currently has the chips in stock and could custom fabricate, but IIRC the minimum order would be 5 boards, so then per unit cost you’re back to aliexpress prices.
[Edit: out of curiosity, I checked to see how my clothes dryer does it. Turns out it measures electrical resistance whenever an article of clothing strikes the two metal bars, closing the circuit. I can’t think of an analogy for measuring filament, but maybe for desiccant…Simple to measure, and immune to damage.]
Was going to say it’s a resistance measurement in a clothes dryer. There are two parallel metal strips mounted in delrin on ours.
Apologies - I also didn’t understand you were looking at this for a different purpose.
But I think you might be in better shape than you think. Those get soldered in reflow ovens typically at 235-250C. They can go as low as 205C for traditional lead solder beads.
Those are for short periods though - preheat, solder, and cool - but the farther you are away from those the more lifetime you should get out of the sensor.
But at filament dryer temperature it may last a while? One way to find out.
Or, mount the sensor outside the dryer and duct dryer air to it? As long as you don’t go condensing you should be ok. You’d get a humidity value and could correct it for temperature since they have built-in temperature sensing. And it has a program-settable heater to prevent condensation - which you might be faced with if you keep the sensor cooler than the dryer.
This is a project to show a two day (configurable) history of relative humidity and temperature in these cabinets with a few other features. Cost is ~$50. Uses Adafruit MagTag and a Sensiron SHT4x temperature/humidity sensor.
Temperature graph, label displays, and units (F/C) are toggleable with the buttons. The humidity graph is always displayed. It also has an optional alarm. The housing and buttons are supplied in a plain version and one with two sets of icons on the buttons and I-IV over the LED ports. Backs with mounting tabs and a weightable stand are also in there.
Code is almost done. I started looking into displaying the graph as a web page but that may be beyond me. It writes the full resolution temperature/humidity pairs out the USB port, though. A Raspberry Pi and you could serve rich pages or just log everything it sees to a spreadsheet, or other application. Or just give it power and ignore the data it streams.
On a 48 hour x-axis display it captures a data point every 10 minutes. (The Sunlu i10 has about an hour regen cycle so 6 points across it will see them fine.)
There’s two ways to capture humidity data - where the data is captured at nominal data point times, and where it captures the maximum humidity seen during the 10 minute window. One method has virtually no time jitter in when the data is collected and the other can have up to 10 minutes of jitter in the time axis for each data point. The advantage of using the maximum and accepting the jitter is the graph will capture any event longer than one second (the update rate of the LED bargraph with some signal averaging). If you open and close the door, it will see the humidity spike.
Using the maxima instead of the values measured at the nominal time causes the noise level’s offset to the data - but it’s a slight offset (0.1-0.2%). The distortion caused by looking at maxima will get worse the more spikes there are. Frequent door openings will make the humidity appear higher than it really is. Worst case would be opening the door every 10 minutes where all the data points get elevated. If frequent openings, the standard data capture might be the better choice.
Using the regular values instead of the maxima will provide more true values for humidity but can and likely will miss door openings. It will still follow changes in cabinet humidity that are longer than 10 minutes in duration (with a 48 hour x-axis).
There are easy ways around these restrictions with a computer. Just collect data as fast as you can and then look at it how you want to see - the broad features or the short stuff. I just wanted a nice graphical display that shows me how the cabinet is doing over time and how my use affects it. The cabinet has its own real-time temperature and humidity always displayed.
Got it running now capturing printer room data on a 24 hour x-axis.
Finally, an intelligent review:
Right from the beginning, he runs my go/no-go test: he takes an empty cabinet at ambient humidity (in his case, 44%RH), sets it at 10%, and shows that it can achieve 10%, at least according to its own humidity sensor..
I’d still want to run the same test sometime later, after the cabinet had already provably removed a lot of water, just to make sure it didn’t hit 10% purely by virtue of factory fresh desiccant. i.e. I wouldn’t bank on just this initial test proving that regeneration is complete enough to drive it down to 10%, but running the same test after it has saturated and regenerated would. Regardless, I give him an A+ for being the only youtuber who filmed at least the initial pass. :100:
I agree. Performance over multiple cycles will be interesting to follow. But sieves are pretty sturdy and they don’t seem to regenerate at the higher/normal sieves temperature so likely easier on them?
Anyway, more positive reviews so that’s good news. Preorders still open too it seems. 15 days until those close.
He sure seems to value dry filament… :grin:
This one had the unit sent special from SUNLU so it is probably not a random one off the factory floor. The humidity sensor will likely have been one of the better ones that passed through quality control. Even if it was a standard unit, it is, of course, the responsibility of a reviewer to mention such things, but somehow most don’t because they stop getting sent things. Which is correct; they should not be accepting things from manufacturers related to their content, if they want people to trust them. This one is a filament channel sponsored by polymaker, a filament manufacturer, so make of that what you will.
It may have received special attention but as long as all the parts are the same as used in production, I’m not worried. The principle of operation is sound. It’s dead simple in operation so there’s not much room for trickery.
Regarding the humidity sensor, their uniformity is high and in general they are all factory calibrated. I’ve laid out a bunch of cheap round humidity sensors on a table and all read the same except a few that were off by a single percentage point of relative humidity. If it works, it’s probably good.
Obviously I don’t have a production unit hand verified to be perfect. I don’t have any unit. But I don’t see much room for Sunlu to cheat on these. They could play with the regeneration timing, but with PTC heaters, those should all hit the same temperatures and any timing changes will be obvious from comparing with the CNC kitchen graphs.
The bigger issue (much bigger, IMO) is going to be people who think their filament is dry and load these up with varying degrees of wet filament. That will keep the humidity high in these for weeks since they don’t heat. Anyone not able to hit the advertised 10% RH should take everything out and see what it hits empty.
The others who will likely claim they don’t work will be those who load them up with silica gel beads. They will reduce the cabinet humidity as long as they are dryer than the cabinet, but if people let them get too wet, they will compromise the ability for these cabinets to hit the advertised 10%.
They will probably do an amazing job finding who is actually drying their filament well and who isn’t. And obviously, there will be some who intentionally use them to dry wet filament even though that will be very slow and inefficient.
For a bit of levity, I’ve stumbled across a category of products that’s loosely similar to filament dryers, but many of which are almost incomprehensibly inexpensive. What’s the category? “portable clothes dryers.” No kidding. Seems like a real niche market. For illustration purposes, here’s a snapshot of one from amazon:
So how hot do they get? Maybe as high as 90C, because I noticed one advertising a safety feature that will shut it down if it goes above that. Very likely just a thermal switch sampling the airstream coming off the heater.
And?
You are trying so hard to say that he’s biased without saying it directly. Let me remind you that it’s not the first time when Dr. Igor shat on Sunlu. There were Sunlu E2, and then inslogic PC-ABS that sunlu magically made perform worse than either PC or ABS. Igor had zero issues pointing out at that.
Although, I do agree that Sunlu sends out curated items. Every single time I see Sunlu/Inslogic send out “perfect” filament rolls with perfect winding - I gaze on my wacked rolls of the same filament.
