I got the supertack pro build plate a few weeks ago and I notived almost right away that prints were not sticking and if they do stick they warp really bad. Is anyone having this issue and is there a fix to it?
what material and what are your first layer speeds? Ive had very few problems with mine. I slow my first layer speeds down considerably.
To me its worth the hassle for the nice smooth finish it gives.
All my new Supertack pro plates stick like glue, even as low as 30c bed temps. It’s the first time ever I can use my X1C with the lid and door closed.
I unfortunately have the exact same problem with the super tack plate on my H2D, severe warping after only 30min of print time. I have started to fiddle around and will continue to try different configurations: my main suspect right now is the Aux fan, I have had better results with tuning it down severely (from 70% down to 10%).
I am mostly using PLA and just the standard first layer speed.
Well I just had 3 successful prints with the bed temp turned at 45°c, the Exhaust fan at 20% and the Aux fan entirely off. I must say the printer sits in a room currently at 18-19°c, the mentioned settings brings the chamber at steady 29°c, perfect result on a relatively large part for 60min print time.
Ok I will try those settings. Also does anyone know if the birds eye camera firmware will be relased soon?
