Support interface only on one tree branch
I did not want to open up the resolved topic How do I print with supports? (Resolved)
Thanks to @3DTech for the pointers I found there.
So, here we are with a little oddness, which just occured yesterday. The slicer ‘forgets’ the interface on top of one support tree branches. I tried Orca and Bambu Studio and played around with all support settings without any result.
Any ideas?
I usually see this issue with normal supports. Fiddling with some settings often makes interface appear again.
Hi Frank.d
Change your support / object XY distance to like 0.2 you have to find the max setting on this with tree supports with small overhangs.
I’m happy the other tips help you out :grinning:
I had to reset my printer to factory and reinstall the firmware update.
I also did the same for the slicer (not sure that was necessary)
I had a lot of little issues like this that I couldn’t resolve. It was very odd but fixable with a bit of waiting lol… Still less time waiting to reinstall than dealing with 100% support failure.
Thanks for all the advice. I will test and report back next week (I am away to see the new King :wink:
Alright, changing the support / object XY distance to 0.2mm (0.3 is already to much) and the tree support branch diameter to less then 2mm did the trick.
Stange, but at least I now know where to fiddle :slight_smile:
Thanks guys!
