The Icon, Redefined — Meet the P2S
The rock-solid workhorse, Bambu Lab P1S — now evolved! The new P2S takes it to the next level, upgraded in every way to give you everything you want in a printer.
5-inch Touch Screen plus 2nd-Gen UI
The P2S features a fully upgraded touchscreen and a powerful processor, running our new intuitive second-generation UI
70% More Extrusion Force & Real-Time Error Detection
The PMSM servo extruder delivers up to 8.5 kg of maximum extrusion force—70% more than its predecessor—dramatically improves high-flowrate extrusion stability. Our proprietary servo architecture samples resistance and position at 20 kHz, actively detecting filament grinding and clogs in real time.
High-Precision Printing, Smooth at Every Corner
The P2S uses a high-resolution, high-frequency eddy current sensor to measure nozzle pressure. Intelligent algorithms actively adjust the flow rate based on these readings, ensuring precise, consistent extrusion across every layer and corner.
Adaptive Airflow System
  • Perfect Overhang No Matter the Filament or Temperature
Unlike traditional cooling systems that recirculate hot air, the P2S’s Adaptive Airflow System draws in cool air directly from outside the chamber. This significantly improves cooling efficiency, letting you confidently print low-temperature filaments with the door closed—without worrying about overhang quality or nozzle clogs.
  • 50℃ Chamber Ready For Engineering-Grade Filaments
The P2S features a flap-controlled Adaptive Airflow System that efficiently seals heat within the chamber while actively filtering the internal air through a high-performance carbon filter. This allows you to confidently print demanding engineering filaments prone to warping, all while maintaining clean, safe air quality in your workspace.
AI Error Detection
The P2S introduces advanced AI computer vision that actively detects common printing issues such as spaghetti, nozzle blobbing, and air printing.
Quick Swap Hotend
“Stage” Lighting & 1080P High-rate Camera
Hardened Steel Nozzle and Extrusion System, designed specifically for stable, long-term printing of high-perfermance fiber-reinforced materials
The P2S features numerous refinements that enhance the user experience
Built-in 2-in-1 Buffer
Effortlessly switch between your AMS and external filament spools for maximum flexibility
Flat Base Plate
The smooth, flat surface makes it simple to swipe out all residue, keeping your printer clean.
Experience P2S printing at its finest.
AM Vantage by @Cormango
House Scene by @BambuLab
BambuBot A1 by @洞洞脑子研造社
Click here to learn more about P2S Specs
The wait is over: P2S and P2S Combo Pricing (US pricing coming soon)
Is the P2S upgrade what you expected? Can it carry the legacy forward as the next-generation workhorse? Share your take in the comments!
The irony is lost on you in this sentence.
I understand why it is delayed though, a tough position to be in.
I expect to see a price around 750 USD.
For context: €519 = ~$600
Hope it is closer to $600, but thats just the world we live in right now.
When will it be available in the United States?
Would love to see some upgrade options and at least be able to swap out my 6 week old P1Ss screen…
Are we any closer to having the same hot end interchangeable between A, P & H series printers?
The H2 hot ends are compatible with all of those.
The P2S uses the same nozzles available to the H2 series printers.
The A series nozzles are NOT compatible.
I’m pretty certain that the H Series and A Series do not have interchangeable nozzles.
A series nozzles are not compatible with H2/P2S but as I said the H2 hot ends including HF are compatible with all printers A1/P2/H2.
Here i Eu the Bambu Lab P2S is €749.00 EUR.
Just bought one with ths AMS.
Sounds really good.
But is it only me, or is this basically an X1C but without some fluff (like lidar, some cooling an different materials)?
but cheaper it seems.
Just ordered the P2S combo and have a question, will there be an upgrade kit for my P1S with screen and maybe an extruded with quick change horned ?
I think they will push X2C upmarket with a chamber heater and maybe a Vortek single hotend + 4 nozzle changer, it will be their “second attempt” after the H2C.
I feel like I have been cheated. I bought 5 weeks ago a P1S combo with hardened upgrade. Now p2S is available for basically less. I know I cannot change the situation, but I at least Bambu van offer something to buyers that just recently purchased one. I own 2 Bambu on the top of that.
This would be cursed on a 256^3 bed.
Never going to happen.
The processing power of the P1S is no where near enough to drive a screen of that resolution.
Hotend upgrade might happen at some point, but it is unlikely. More likely is that someone is going to figure out how to do it given spare parts and some tinkering.
I feel you man. I bought mine 5 weeks ago too.
They also lowered the price of the P1S considerably over the past year.
You got exactly what you paid for, You were cheated out of nothing.
