Title: P2S knocking over supports / nozzle scraping infill
Something seems amiss in that while I do not have a P2S, an error should spit out that says there is a g-code path conflict to prevent just what seems to be getting described here.
As I recall it will manifest during the slicing process. Are your printers configured to “Print by Object” or “Print by Layer”? Print by Object seriously constrains the available buildplate volume
Introduction to print-by-object
When there are multiple print objects in one plate, you can choose to print multiple models at the same time (by layer, the default print sequence), or you can choose to print them one by one. Print-by-object can reduce stringing and oozing caused by traveling between models. And if one model fails, it usually does not affect the printing of the other models when using this mode. You can select this function in the Special mode:
Print by Object
Thanks! It’s always a single object on the plate, printed by layer (default), and the slicer shows no g-code path conflict warning. The toolhead hits the tree support trunks during normal printing.
Thanks! I’ve only tried Z-hop up to 0.8 mm (Spiral Lift) so far, so 1.5–2 mm is definitely worth a test. I’ll run my test model with tree supports and Z-hop 1.5 mm (spiral) and report back.
Did you notice any side effects with such a high Z-hop – for example more stringing or blobs, longer print times, or visible marks on the model? And do you use the 15 mm brim on the model itself, or mainly to keep the support trunks on the plate?
Can maybe using another Slicer like Orca solve the problem?
Have you done the long bed level/position calculation recently on your printer. The one it tells you will take 20+ minutes to do?
For the nozzle tip to strike either the model or the supports and NOT give you the error seems to say the nozzles physical location (in the real world) is different that where the nozzle thinks it is, in the math equation.
Unchecking “Independent Support Layer Height” fixed the issue for me.
Out of curiosity and in the interest of learning a new tidbit of information on my P2S, I opened a random file in Bambu Studio and hunted down under “Support”, and found at the bottom a Box that sez “Independent support layer height”, and found it is checked. Glad of that.
I often run down these tidbits in the interest of trying to learn more idiosyncrasies of my P2S. I have had models that will break loose, but I have sometimes found success in printing by slowing down the printing process, or changing to a different rendition of the same model.
Anyway, Thank You to those pointing out that setting in Support. :clap:
Firmware! 01.03.000 bad! Downgrade/rollback to 01.02.000.
I’ve already brought up this topic, but they don’t believe me.
Or they downloaded it with no issues.
If you see it as a real problem put in an issue on Github
Have you checked yet? Did you manage to install the old firmware?
Exactly.
Csaba has already started a thread about this here on the forum, not on GitHub. So far, he and one other user are the only documented cases reported in the forum. There are currently no corresponding reports on GitHub and no broader pattern of similar reports elsewhere.
It appears to be an extremely isolated issue. Otherwise, the forum, or at least GitHub, would likely contain significantly more reports. Based on the information available today, there is no factual basis for a general recommendation to downgrade the firmware.
That does not mean Csaba is right or wrong. However, without evidence and proper documentation submitted through the appropriate channels, it is difficult to draw any meaningful conclusions.
They are complaining about a similar error.
“They” … :rofl:
Source: One comment buried at the bottom of the thread which deals with a completely different topic.
Ok. I still think that this FW is not good and that is what is causing the error.
That is a possible outcome. Lord knows I’ve encountered similar bug-a-boos with updates in the past. Not so much with firmware updates.
But with so many different computers, running so many different possibilities of software’s and drivers, the possibilities of a flub looms very real with the General Public.
So I refrain from grabbing the brass ring too soon after something comes out. My days of bata testing are behind me. Too many opportunities for buggy updates, or updates that need to mature a bit. So let somebody else suffer the pains of refinement first. Then when the bugs have been worked out, try the change.
But I sure do not trust early releases as much as I once did. When something is in revision 1.xx that means it has had a lot of revisions to try and correct it. If Update 1.16, that is 16 revisions to correct things. No thank you, I’ll wait. Sorry you are one of the Guinne Pigs.
Or as I call it: Updates to update the update to update the updates that didn’t update the original update.
Usually, I don’t install updates right away, but this one was tricky because there was a beta version with a lower version number.
Yeah, it “gottcha”. I empathize with you. Hopefully future revisions and maturing will help.
A bane of my life is Windows Updates. I have a laptop loaded with specialized programs I use for my Astrophotography. Windows isn’t mature enough to not remove or break drivers those applications use. So, in order to not repair, fix, or reinstall my faves, I simply block Windows’ crap updates. Windows thinks all 3rd party apps are viruses because they didn’t come from their store. So they break them by damaging or removing drivers.
Yep, very familiar with buggy updates that are half-baked. And reasons to avoid early releases of changes. Hope you have less troubles by versioning back. Riding the “cutting edge” isn’t just blo ody at times, sometimes it perforates a bowel and covers us with crap. I learned that by staying back a bit, although I might get blo ody at least the crap flies over my head. Live and learn my friend. Live and learn. :wink:
I’ve given up on this; everyone can use whichever firmware version they prefer. I’ve shared my opinion, and several of my prints confirm it—the nozzle actually makes contact with the infill; I can hear it touching while it’s printing.
Currently, I use Windows 10 as my operating system. I also use software for astrophotography—FireCapture, Autostakkert, Registax, WinJupos, Photoshop, Astra Image, LuckyStackWorker, etc.
That is precisely why I haven’t updated to Windows 11.
If you feel like it is an issue write it up in github. If you feel it isn’t worth that effort, that is a message in itself.
Kind of confused as to how touching the infill is a problem since the infill is part of each layer so it is always laying down the print layer by layer. Just randomly pick layer 58 on a print of 200 layers, each layer will consist of walls, inner and outer. and infill. The sequence and speed of extrusion may vary within a layer but it is all on a set layer. It does not bounce around and print layer 50 over here than print layer 51 somewhere else.
