Using support filaments: Performance hits?
Is there a performance hit from using PETG or PLA support when printing on a P2S? I’m thinking that depending on the model and its orientation, there must be some hit simply from changing the filament. Is there a way to reduce any potential performance hit?
You’ll need to be more specific about what you think a performance hit is.
Part performance? Printer performance?
Yes, printer performance. I was wondering how much extra time, if any, I can expect since the P2S will need to swap filaments to print a support. And, it will probably do that many times.
That depends so heavily on the model. It can add a S*** ton of time or almost none.
I would just slice it in studio and see what happens.
make sure you use the support filament just for the single interface layer and not the whole support / tree
I estimate your machine takes about 100 seconds to swap filaments through an AMS, so it’s just going to be the number of layers that need support times 100s.
@Eponymous Thanks. That’s an important point to remember.
If the original detail is in single color there will be big hit more or less depending of the size of the print itself. As not only you get more filament changes but also you get the prime tower enabled. Which is more time and more filament.
If the print is multicolor already most probably the difference will be mostly related on how many more changes you need to do because of the support material.
And you can very easily see the exact answer for a given model, if you just open Bambu studio, load the model, enable support and set up the materials with/without separate material and see the difference.
I have pondered this switherroo of filaments. I always wonder why? What is the advantage?
The one complete stopping block for me is why generate so much “Printer Poop” because for one example. My P2S generates cowpies of waste at every filament change.
So what could possibly be an advantage? Maybe if you are using a very costly material ($50 p/kg.) for the main, and you could save costs by using a cheaper material, rather than the expensive for wasted support structures.
That is why multi head printers are so attractive to me, but not to my wallet. Printer poop is the enemy.
The advantage is better support interface quality and easier to remove supports. In the case of very expensive materials it can be a cost savings. That’s up to you if you value that.
What I don’t value is waste. And printer poop is waste. I’ve learned what to avoid and what to look out for, mostly through the school of hard knocks.
