By the way, after returning the first one, I bought two X1C combos on the same day (sometime mid April). One turned out to have minimal banana and quite acceptable (I guess worst dip was less than 0.10 at 60 heated). The other had a V3 bed but with a dip going as bad as 0.50. The first one is a joy to use, the second one is being returned.
It is a tragedy really. Bambu is perfectly capable of churning out nice, reasonably flat beds⦠I just think it sucks that the end user has to play this lottery. This is a fact, not a blanket statement.
Exactly why you kept getting called out. Plenty of us with nice, reasonably flat beds
I agree. No one ever doubted that or doubted you that your original bed had issues. It was the repeated statements that others didnāt/couldnāt have flat beds or were only printing āEtsyā parts or whatever other nonsense you were saying that kept causing us to rebuff you.
So they did let you return that one? Didnāt have to do a chargeback?
Nope. This is a lottery Matt. Nonsense is ending up with a banana bed and using chargeback threat to force a return to play the flat bed lottery. Donāt be daft. Convincing people that Bambu is mostly delivering āreasonably flatā beds on $1500 printers is deception.
Other large expense consumer products from well established manufacturers also have inherent lottery games - like TVs. I have had to return multiple expensive plasma and OLEDs over the years for panel defects. It sucks, but manufacturing lotteries are not unique to Bambu. Most consumers donāt know better or donāt care about these things, and simply accept the products as-is.
After several months of testing and lots of back and forth on the protypes, Iām finally getting, what appears to be a final production sample from our machine shop. Hereās a QC check of the machined surface. Measures flat to about 0.0015"
Pulled the cool plate sticker off the stock plate and mounted the tronxy glass 255mm² plate with some high temp rtv (didnāt have a sticker and my shop is right thereā¦). I know there is probably a bunch I can do to get this PERFECT but this will work for what Iām doing now and for the foreseeable future.
Plus, itās kind of nice have a solution that I can pop in when I need āFLATā and just use the pei plate for everything else.
No temp issues, temps are about 3c lower than what is commanded. I havenāt found the variance to cause any issues with my current filament profiles. Iām using a ālittleā bit of glue stick then spray with IPA and swirl with a paper towel. After print I then just spray a bit of IPA and swirl again. Seems like 5-6 prints before a full clean (soap and water) then start over with the initial glue stick application. Very doable for me as I generally donāt like using glue stick at all. Itās working great.
I printed the little qr code for āTextured PEI PLateā and attached it to the plate for two reasons. My other and favorite plates are PEI so I can leave it set to that setting in the slicer, also so it doesnāt give me the āerrorā where I have to hit āresumeā every time I print with the glass plate.
I agree, with the nice top coating on this tonxy plate itās really easy. Could probably use anything even remotely āstickyā and youād be fine.
It does the nozzle wipe yes but not on the glass. It ends up just wasting some time back there as I havenāt edited out the gcode for the nozzle wipe. A couple reasons Iāve decided not to edit the gcode, mainly ⦠Iām lazy and I donāt (wonāt remember more accurately) want to change the settings back when I decide to print on the regular plates. It doesnāt hurt anything⦠just a bit of wasted time. Which kinda helps on a first print actually as the glass takes longer to heat up than a regular plate. So all in all, it provides me with a cheap and simple āplug and playā solution that I donāt have to rack my head about every time I use it.
Honestly, Bambu should look into an accessory like this to sell in the Bambu store. Call it the āFlat Plateā ⦠Bambu if youāre listening (reading)⦠Royalties and honorable mention to the Goat when this happens ok?
I guess I missed your question. The lidar / for calibration works perfectly. I think mostly due to the matte black surface on the tronxy plate. Iāve tried the different filaments so far, 2pla and one PETG. All of them calibrated just fine. On that note, ABL works just fine as well. The load sensors donāt have a problem at all. Honestly it just works just as well as a regular Bambu print plate. Couldnāt be happier.
