I have been using the gallon ziplock freezer bags, and they are much thicker than the regular bags.
I also use them for food as they don’t get freezer burn quickly. I use them for crockpot and instapot meals as they don’t leak.
I wasn’t name-checked, so, I missed this one.
I did, the Sunlu S4. I bought mine three weeks ago, but it wasn’t in a sale, although it had an Amazon discount. I got it for £99, currently £125.
I might switch it on this weekend. I am not sure why I bought it, possibly because of the high-end filaments I purchased recently which all say "Dry Me First’.
Possibly peer-pressure!
I also store my filament in zip-lock 1-gallon bags with a silica bag in each one.
I think this helps me not have to dry everything as everyone else seems to need to. I imagine the “Dry Me First” filaments might ruin my track record though.
I have only ever dried filaments twice, once because it was brittle and I was experimenting, the first time I used it was because I had just purchased my original dryer.
@movingimage Thank you for posting that! That was by far the most informative youtube video that I’ve yet seen on this topic. Finally some real science! Well presented and useful to know.
Most of everything else on youtube is little more than handwaving, with little to nothing to back it up.
What he unfortunately didn’t explore was how long it would take equally moist PLA, PETG, TPU, etc. to dry equally as dry (0.2% to 0.6% percent moisture by his reckoning). Or, for that matter, are the optimal dryness targets different for different types of filament? There’s quite a lot of unknowns remaining that has yet to be elucidated.
Agreed. I found it interesting how the drying temp to length of time required was logarithmic. So, even getting a dryer that could do 80c instead of 70c would make a big difference.
I’m new to all of this and I am looking for a good working filament dryer that I can actually use. Do any of you have a recommendation?
Start from the top of this thread. You’ll find lots of recommendations.
Here’s an AI generated summary for you that summarizes the recommendations as discussed across the entire Bambu Lab forum:
In analyzing the Bambu Lab forum discussions about filament dryers, it’s evident that users share a variety of recommendations and experiences across different dryer models and methods, including innovative approaches to managing air humidity using desiccants. Here’s a comprehensive summary including the detailed points on desiccant usage in air drying:
2. Print Dry Pro 3:
3. EIBOS 3D Series X: Easdry:
4. Homemade and DIY Solutions:
5. Desiccant Use and Air Drying Techniques:
6. Quality and Safety Concerns in Budget Models:
7. Experimental and Innovative Approaches:
These insights show a proactive community engaging in optimizing filament drying techniques using both commercial products and custom modifications. The integration of desiccant systems to control and improve air quality within dryers emerges as a significant theme, pointing to the community’s deep technical engagement and innovative approaches to 3D printing preparation.
I live in Salt lake city Utah it’s fairly dry in the summer but er use a swamp cooler which keeps the humidity in the house quite high in the summer.
I couldn’t figure out how to add the pictures to the post, so here is the write up.
The first print from the spool that was left on the shelf unprotected for 10yo
finished with out incident, (I credit the Bambu A1 for that.) but it was a train wreck, brittle and full of errors.
I set the A1 to reprint and the second print was pristine. Not brittle and no flaws. So once the outer layer was cleared off by the first print the spool was fine, I printed the entire spool with out problems and all 4 of the spool halves I printed came out clean with no issues. I did run out of the weathered filament shortly into the last spool half. I simply connected the other old role and finished the print.
When I get some higher temperature filament I will most likely print a new batch of spools without the open sides, as I think the success of these roles can in part be attributed to the solid sides of their spools not letting the environment get to the filament.
I’ve always just used my old toaster oven on the keep warm function and I haven’t had any issues with it yet.
well it’s my turn to come to this thread, i’d like to ask if someone has hands-on experience with the sovol sh02 and your thoughts around it, i’ve already seen some reviews, but you never know how candid they are - sure the reviewers say that it’s always their opinion, which i believe, but i’m also sure they don’t want to damage the relationship they have with the brands
so do you / have you owned it? plus and cons?
for context i have the sunlu s2, it’s ok, not great, and i’m tired of only being able to dry one at a time, but also think the S4 might be overkill (and it’s really big
@MZip Hi, well I finally wrapped up my little Sunlu S2 project. Thanks to your excellent guidance in regard to temperature/humidity. I had never really thought about it until drying plastic filament came into the scene. I have made a couple of mods to my S2, and now it dries the filament nicely and predictably. I decided to publish the .3MF files on MakerWorld. Here is the link.
My filament dryer is a sovol dual spool dryer. It’s maximum temp is only 50c but it works for me. I also use it asa drybox when printing TPU or if I am printing and don’t want to swap ot the spools in the AMS.
When I swap out spools, I put them in vacuum bags with fresh dessicant bags then dry the spools in the sovol before use. The AMS has the full compliment of dessicant boxes filled with orange/green pellets.
I bought the Sovol dryer because it was a dual spool dryer at a very reasonable cost. Yes I bought an expensive printer but that doesn’t mean I still have the funds to buy super expensive ‘nice to have’ items to go with it The humidity levels in my part of the globe are pretty low, usualy in the comfort zone but still can affect the filament.
My solution will not suit everyone but please don’t try to convince me that it is the wrong solution because my solution works for me.
I’m curious. Which tool did you use to analyze every post in this forum?
chatgpt
12345678901234567890-
Very cool! I had no idea ChatGPT could crawl every post in a forum. That must have taken hours.
Or maybe it didn’t really crawl the entire site ![]()
I forgot how long, but definitely less than 30 seconds. Maybe as little as 10 seconds. So, yes, insanely fast. This suggests it must be working from an already cached copy of the forum.
Only thing is I’ve found the more technical the questions, the less likely AI is to get answers correct. It seems to handle easier stuff ok but expecting to get authoritative answers when there is controversy in wherever it looks can be an issue.
Anyone with specific technical knowledge can test it for themselves. I didn’t test it rigorously but one wrong answer is enough to know with AI, if answer accuracy is important, folks need to double check and verify.
Summaries seem pretty good though.
It likely used its search feature to search the web and provide a subset of the top results – like the results you’d see if you google something like “3d filament dryer site:https://forum.bambulab.com”. You’d need some kind of custom ChatGPT implementation to actually search and summarize every related thread in this forum.
