Why am I continually underwhelmed by the X1C experience?
So I’ve had this printer for a year or so now and when I first got it there were a ton of gripes with the slicing software etc, most of which have been resolved over the past few months. But one thing I can’t get out my head is how average the fine detail print quality is on these printers. For all the sensors and technology in them they continually get outperformed by my £400 Flashforge Creator Pro 2.
The first issue is the size is never true to model, it’s always smaller, but never uniformly, some bits are okay and other bits are not, so it makes fine adjustments with the slicer software impossible, you actually have to edit your model in the specific areas especially for this printer. That isn’t a good trait.
The other issues I am continually facing is how poorly this thing does fine detail, especial when it comes to text. An X for example, you might think it would be simple. Well it is for my Creator Pro 2 with a 0.4mm nozzle. The same X done on my X1C, with the 0.4mm nozzle there are hairlines gaps in the structure of the X where the wall doesn’t meet infill, and no matter what settings you adjust it doest change it. The X also has the webbed feet look in the centre.
So, do what all the people recommend and get the 0.2mm nozzle, because it’s a must for fine detail they say. Okay well after investing in that, the X now resembles a roman X with flared end points. It really is something ridiculous, I am probably thousands invested into this printer and it continually gets out-performed by my slow but sure Flashforge
Anyway, rant over, I just needed to get this off my chest as it is really upsetting me lately that I’m so cash deep into this ecosystem
I have used many different printers and I can tell you that my X1C is the best printer I have ever used in terms of speed, quality and user experience.
Have you ever entertained the thought that your issues might not be caused by the printer???
Yes, you’re right, the issues are me being stupid, you got me!
Joking aside, I currently own 3 other printers and they all do fine detail better than the X1C. The reason I invested in the X1C is because of the AMS system.
Before using BBL printers I considered myself a pretty wel experienced 3D printer and I had tweaked a lot of printers an profiles to get good results…
Only to find out that most of what I learned did not aply to the X1C. I had to relearn what 3D printing was all about and the knowledge I had gathered before didn’t aply anymore…
I am not saying you are stupid, but I have a hard time believing your machine is not capable. I can tell you that mine is very capable. Without any tweaking of modifying the machine or the profiles. I print mostly standard settings.
Have you done much upgrading of the machine or settings?
Upgrading in what sense? I didn’t expect to need a uni degree to get it to print a uniform looking X if I’m honest
Lots of people get in to all sorts of issues because they modify their machine thinking they are “upgrading” it.
Did you make changes to your X1C?
Can you show what is wrong with your X’s?
Yeah will take some pics for you, just need to put the 0.4mm nozzle back in
Also, no mods, I don’t believe something this expensive should need modding to work properly lol
Hi,
After almost a year, I am still overwhelmed with the X1C.
Sorry that you aren’t getting the same experience.
Some notes which I found to affect the print quality significantly in comparison to other printers:
  • dryness - the printer seems quite sensitive to filament moisture.
    My other printer performs better with a slightly wet filament than the X1C.
  • The printer is relatively fast, so to ensure strict tolerances and great details, I set the printing speed for the outer walls, top surfaces and detailed regions at a lower speed.
  • chamber temperature - for the first time, take note of the chamber temperature.
    Depending on the printer’s surroundings, you may need to adjust ventilation (e.g. door open).
As you have another printer, I assume you calibrated your filament.
Interesting. I’ve had my X1C since December last and it prints very accurately for my mechanical parts. It compares quite well to my older QIDI printer (which still works well but not as good as the Bambu).
I tried the latest Califlower calibration tool. For prints that should be 100mx100mm they were 99.75mmx99.80mm. My skew was 0.06 degrees. That’s some of the best results I’ve seen from a mass produced consumer 3D printer. If 0.20-0.25mm difference on a 100mmx100mm parts is a major deal breaker, you can fix it in Orca Slicer.
Without any adjustments I had no issues with everything working on the torture toaster using ludicrous speed.
I do use printed parts in conjunction with existing mechanical parts. To expect sub-millimeter accuracy seems a bit too much with a system that uses toothed belts to move the important parts around. I use 3D printed parts in my machine shop but not at that level of precision. I have printed gears for use in lathes that have stood up for years but then they don’t require that level of precision.
I would expect that there is some place in the slicer software that can be changed to achieve whatever accuracy you need assuming the hardware can support that level.
I presume these errors you all are talking about is what’s remaining after accounting for shrinkage? Under the filament profile, the slicer can automatically compensate if you know the expected amount of shrinkage.
Those were my measurements before doing any adjustments in the slicer to account for shrinkage. I assume you are talking about after adjusting for shrinkage if you expect +/-0.05mm.
I have been doing this professionally for the last 6 years and I concur with those here that say the X1C is the best printer I have ever used. I just brought our second one online and am waiting for the additional 5 to show up. We work mostly with CF and exotics) I really would like to help out like most people on this Forum and get you happy with your gear. Have you done some of the so called quality of life mods?
On the fine details:
As far as I understood, the input shaping has the effect of very slightly rounding sharp features. Maybe you see that? I think, If the base that the printer stands on is less stable, input shaping has to suppress more frequencies stronger, which will lead to more affected corners.
My printer stands on a sideboard, which is attached to the concrete wall with two screws. There really isn’t the slightest vibration. Is your printer on a stable surface? Hopefully you don’t use those soft feet. I don’t understand why they became popular. They are directly harmful to print quality in my experience.
Have you tried printing at slower speeds, similar to your old printer? Just for testing, not saying you shouldn’t use faster speeds.
Of course your unit could just have some fault.
Could you show an example of that non-uniform undersizing? I can’t imagine how to understand that.
And i would also be interested in side by side fotos of the X, one from X1C, one from Flashforge.
Seems like an empty complaint without specifying what you have for Layer Height and Line Width, among other details. You didn’t even mention the filament type. That plays a huge role in the quality of prints.
When I got my X1C late last year, I thought it was the greatest thing since sliced bread. Talk about plug-n-play, I was up late for a couple of weeks playing and printing. It was so much fun, I ordered another AMS, then another and another. I now have shelves of filament. You couldn’t pry this printer out of my hands.
I’m no expert but after reading about all the problems with other printers, I went straight to the X1C as my first printer. I couldn’t be happier. If I had the room, I’d be buying another just to keep up with the never-ending free models. I’m hooked. I haven’t had time to get back to my Laser. It’s gathering dust out in the shed. :crazy_face:
I’m sort of surprised.
When I bought the X1C about a year ago, I was so concerned about calibration my models were friction fitting 32mm bearings, so I wanted ~0.01mm tolerances, I modelled a suitable calibration plate graded at 0.005mm - or so. I was surprised and happy to see 32mm holes within my tolerances. I may have slowed the printer down a bit.
Sure - with pin-holes of 2.5mm or under (I ran a few models with 1mm holes) one needs to calibrate those, but I don’t see much variation across the plate.
My only gripe with the printer (for its price) was to do with PEI adhesion failing after a firmware upgrade.
I do not have other printers. I do have a laser cutter, and I’m lucky to get 0.25mm tolerances with that.
I’m not saying that you are wrong - but it’s not my experience.
Oo-er, I got my numbers wrong by an order of difference. Eg, the calibration guide was 0.05, not 0.005. But regardless 0.25 is … erm … pretty rubbish, and I’ve not seen discrepancies anything like that large - except for very small holes, as I mentioned before.
The things TS says dont match with my experience with the X1C.
Mine is dead accurate. Printed several test shapes and all we spot-on. 25.00mm cube was 25.00mm in XY and 24.98mm in Z. I also work alot with ball bearings and they fit perfect when i use a 0.1mm tolerance.
I think i printed somewhere between 500 and 1000 things and nothing was disappointing, except small pinholes <2.0mm (which was already mentioned by another person).
Also the detail of letters is perfect. I use letters quite alot and they come out perfect every time.
Maybe you have a machine with a hardware problem, because as you can read they can be great. Shame you dont have the same experience as me.
This is a recent design with small letters. I have no complaints at all. Are your results simular?
